Steel canopy on Ali tray
Hi all i’ve Just purchased a steel canopy to put on my aluminium tray. I’ve bolted it down, should I but rubber between the canopy and tray to prevent rub and then rust?
I would, what I use is coreflute like they make forsale signs out of . You can buy a 8x4 sheet from Bunnings for about $10
Skurfer
I don't have anything between mine. Take it on and off quite frequently. It's bolted with 6 bolts. 4 in the base at each comer and 2 on each side of the front. Can't see how it could move. I guess if you use over centre latches like some do there could be a bit of movement.
