Starter Motor Grinding
Jzone101
My starter motor is making a grinding noise, what could it be, I have check the flywheel and it seems to look ok no teeth missing? Is the starter solenoid or will i need a new starter motor or a rebuild etc?
Thanks
Jonathon
Goin Hard
when you turn the key to start the engine does it make the grinding noise then or does it make a clunk noise and nothing happens? if its the grinding noise it could be the pinion gear teeth are not meshing on the ring gear teeth and its just rubbing against the face of the teeth.
