sqweak in clutch
Willow_23
my swb maverick has a sqweak when my foot is off the clutch but when i engage the clutch it stops. wouldn't have a clue what it is:mad::mad:
kruzaman
G;day Willow, it sounds like your throw out bearing is on its way out, the bearings on modern clutches rest on the pressure plate when they start to wear a little they may squeak when you put them under full load i.e you put your foot on the clutch pedal the bearing spins properly and the squeak goes away. On the bright side they can last along time in this condition it just bugs the crap out of you. On the dark side Nissan Boxes are crap to pull out. May I suggest turning up the radio, fit mud tyres or use ear plugs.
Regards
Lee
frosty
Has it been wet lately?? If so, maybe a little surface rust on the thrust bearing. If so, it may go away.
russell789
i agree with these, i even agree that nissan gearboxes are crap to remove! big as a house and about as heavy too
crtx
def will be spiggot bearing what frosty has mentioned so gearbox out to get this fixed.
croozza
Definately the throw out bearing.
Patrol Boxes are much easier to get out than a Landcruiser box also as you can get to all of the bolts relitively easy, the landcruiser ones are tucked up too high and the top bolts are a pain in the bum, then the bell housing fouls on the firewall and so on and so on, I would much rather remove a Patrol box than a Landcruiser one.
frosty
I reckon don't touch it. See what happens. If your confident enough, Squirt a little bit INOX through the little tube through the clutch fork at the side of the bell housing. Don't aim it towards the clutch plate.
It shut mine up for years, til the engine died.
