Squeaky Suspension
DazzaMTD
Me hilux is making noises!! i'm sure its the back suspension, is there anything i can or should do?? Or are they just the sounds of a 4wd:D
LowLux
Is it the shockers or springs? If shockers, get rid of em, if springs..just spray as jimbob says.
frosty
If it's shocks, they'll rattle and bang. A Hilux, you'll have those old fashioned things called Leaf springs. There should be some clamps each side of the axle. Sqeezem up and inwards a bit and see what happens. You should'nt lube them. I can't remember why. Long time since played with cart springs.
Jonathan
check the leaf guides that the leaf spring are not rubbing if not then just spray them with a good lubricant
