spraying alloys black
choppingblock
I recently read in a 4x4 build up mag that a fella had his factory alloys sprayed black , Now is that something that is done often or is that really something rare , cost and strength
muzza01
Remove tyres and lead weights from wheels. Pressure clean the wheels. Scuff all the wheels with scouring pads or steel wool. Clean down the wheels with prepsol. Spray the wheels with 2pac primer.
Spray in 2paac black.
Rough cost retail,
Scouring pads $5
1 lt primer and thinners $40
1 lt 2pac gloss, kit and thinners $50-60
Remove tyres, refit and rebalance $60.
A lot cheaper than powder coat and will look great presuming you can spray.
Good luck.
cb, I replied to your other thread in the general section, so will copy here for you too.
Definitely doable cb . . . tyres off, good rub down with 600 W&D, little wipe of fine polyester 2 pack putty into any scrapes etc, fine paper block these flat, light etch prime, single coat 2 pack primer, then 2 pack em.
Maybe a satin finish, unless you like glaring shiny gloss wheels
Could be done without a booth, but with 2 pack anything in the air will stick to em like the proverbial until tacked off . . . using a fast hardener would be fine for rims, tack off in 10 mins at around 25c.
You'd also need a proper respirator mask to protect from the isocyanates in the hardener, like the popular Sundstrom mask like the Basic Kit - ABEK with organic filter, or other model Pro Kit (below the Basic Kit) with same filter.
choppingblock
cheers les, I pick up a new car in next few months and if don't get one with black rims may have a look into this , just for the fun of playing with the new toy ,
ALUX
Mate I used VHT wheel paint. 14 bucks a can and I used 2. Clean the rims well with soapy water, then grease remover. Just leave tyres on and mask it with tape and newspaper. Mine came up a treat and still look good after 2 years. 2 PAC is awesome, but there are cheaper and less toxic options.
A
Sent from my iPad using Tapatalk
