Spotties on the Nissan Navara bullbar, harder then I thought or is it?
SEATO
2007 nissan navara, bought some upgrades for it from arb, suspension, spotties, snorkel and compressor, instead of paying them the price of the gear again to fit it, I spent a Saturday at my cousins and put it all in ourselves took a good 14 hours and plenty of beers but it all turned out spot on , except for the spotties!!! Being the last thing we did that day, we had to undo all 500 nuts and bolts to get the bullbar off to be able to get a socket onto the nuts holding the lights, being late after a big, sometimes frustrating day we pretty much just lined them up by eye, tightened them up and bolted the bullbar back on.
Driving home that night it became obvious they weren't aligned properly, my cousin having a little time on his hands as I do, they've been hunting possums for months now!!
Has anyone overcome the drama of having to take the whole bullbar off (having to try and prop it up because of the wiring) to adjust the spotties? And is there a fool proof way to align the spotties correctly in your driveway if taking off the bullbar is the only way? Otherwise lining them up on a night drive can be done!!
Cheers for your help, it's about time I fix up the possum hunters
prawns
I have no idea how your supposed to adjust spotlights/headlights when they arnt already mounted and in position on the vehicle properly- what a crap shoot!
You sure you cant just remove a stone tray for access to those bolts? at least then they stay mounted and are actually adjustable by eye - You could line them up by reversing out your garage and using the roller door for measurements, but perhaps the best way is parked on the street so you get a better distance of light for better adjustment
Eightyeight
Assuming you have yet to rectify this:
If the bar is really preventing access and the ball is underside of the bar for adjustment, I hate to say multiple removal.
Take the bar off, tensions spotties so you can move the around with some force but remain in place. Find a dark deserted flat area, aim your lights. Then do a remove and full tension there before departing.
Sounds painful? Yep! Surely with the right universals and extension bars you can access from under the bar with your plate off though. Can't speak for the ARB bar, but there has to be access. Of there really isn't, maybe explore removing the plastic grill and access infront of radiator with open bonnet?
80lover96gxl
Might sound silly but is there any adjustment in the bar itself.
If the spotties aren't to far out of whack maybe a slight tweak of the bar might be a hellova simpler than pulling the whole thing off and hoping you have the adjustment right.
Just a thought.
cookie64
Any chance of some pictures to give us idea of what you are facing
the only other thing you could do is to get a laser and set it square to the face of the light and measure the height then adjust accordingly
cheers
