spot lights
Big Merv
Iv'e fitted a pair of roo lights to my bull bar but would like to fit an extra pair.could i run them off of the same relay and switch?or would i need to run a seperate relay?:eek:
03hilux
better safe than sorry. I'd be running a whole new loom, switch and realy. This will prevent system overload, and possible vehicle fire.
U can run them off the same switch, but u will need another relay. It also makes it easier to diagnose if there is ever a fault.
Sent from the bat cave using tapatalk 2
In Victoria its illegal to run them on the same switch as high beam...I have used this type with the mouse switch (or you can use the rectangle switch next to it in pic) and hasn't missed a beat...Just stuck it to the dash using Sikaflex....
Oh yeah i also use waterproof connecters to go to the Spot lights..
Sidewinder Harness
Goodluck
You can get those harnesses from super cheap. I have 8 spotties on my truck at the moment on different switches. The bullbar on a switch aswell as highbeam, and the 4 on the roof on a seperate switch to the the bar, then 2 at the rear connected to the acc power. Each pair of spotties have their own relay....
As long it is fused and can be switched off they usually dont bother u...
