centaur
My son and I have just finished replacing the small bypass pipes on his 6VD1 (V6, Petrol) engine.... This involved pulling down the COMPLETE front of the engine, and removing the cambelt/pulleys from both cams.
We have got it back together, but now it wont start.
The problem we had, was trying to reset the cam timing, which I am pretty sure is wrong. When checking the internet, there seems to be some confusion regarding where the timing marks are, and what ones to line up with..
Which one of these is correct. I had trouble setting the timing on a consistent theme, the left back (as seen from front) was at the dimple, BUT, the right bank (as seen from front), would not line up with the dimple, it keep sitting at 1 oclock. The Crankshaft was correct, though. We have no markings on the belt to help with this, just arrows stating direction of belt. The engine turns over fine, just not firing.
Also, what is meant by this engine is a non-interference engine????
NEED HELP........
NEED HELP........
