Solar setup
MUX STX
Planning my solar setup, I intend only running led lights and will be using 120 watt panels to recharge.
I stupidly purchased a battery box from the caravan show last week and now restricted to a battery size to fit the box.
I could of course sell the box and get a bigger one, which may yet happen.
What minimum size deep cycle battery would I require?
Looks like the biggest I could fit in the box is about 80ah, is this big enough for camping on a average of 7 nights at a time?
Thanks for the help
Are you just running some LED lights off it or a fridge as well?
There are a lot of variables to consider but 80 a/h is on the lighter size for capacity. 100 to 120a/h is probably a more commonly sought size
I use a 100w panel with 100 amp/hr AGM battery, can keep up with fridge cycling on / off 24hrs, and minimal leds running for a few hours at night.
Tops off battery no probs too if camping all day in good sunshine . . . might struggle to do this if it was overcast all day.
Panel produces 6amps in full sun, 2 amps under very heavy overcast skies.
With 80 amp/hr AGM, I am sure you'd have no problems at all running a heck of a lot of leds right through the night, and recharge battery easily through the day, as long as you aren't running a fridge too.
MUX STX
I was looking at 100ah but now find some size restrictions, fixable of course.
No fridge just lighting, so I was thinking 80ah may just be enough.
Thanks
Chatty
Well, despite what others are saying, I am running an 80 A/H gel battery (Thumper) with a 120W panel and find it is more than adequate to run LED lights and a BIG fridge for as long as I need, unless the weather is totally lousy for several days running. But then, I just pick up from the 85 A/H auxiliary battery which gets charged whenever I run the Paj.
If all you are running is LED lighting, then the current draw is likely to be less than 5 amps, so you should get around 12 hours out of an 80 A/H battery - which would equate to around 3 nights or so without any charging.
Keep in mind that bigger battery capacity is great, but it comes at a cost - both in the hip pocket, but also in weight.
Tink
I try to keep my batteries above 70% wherever possible and never below 50%. But this rule varies based upon how much you value cold beer over increased battery life. Have attached a couple of graphs which may assist.
Chatty
You shouldn't run down AGM batteries too much though, best to only take down to say 30 - 40 % max before charging.
The thinking I've been told on modern AGMs is that discharge by 80% is quite ok, but I would typically only go to about 50%
But, don't forget that 50% discharge is based on voltage drop, not amp hours - you will get about 80% of the current capacity out of the battery for this.
oldlux
Could you possible provide some info on what sort of LEDs (wattage and or Amps), how many and for how long you intend running them for and we could probably give you an informed answer to your question. Without that info we can only offer wild best estimates.
MUX STX
Thanks for the responses, I will be running approx. 4 x 9 watt led strip lights.
Clearly they will not all be running for any particular time.
At a guess maybe 36 watts for 2 hours and 18 watts for extra 2 hours, so really not a lot of draw on any given night.
Thanks
oldlux
Thanks
OK that is about 9 A.H. per day so 4-5 days without a recharge would be fine and not draining the battery excessively. Now your 120W panel should produce around 6.67 Amps in full sun so about 1.5 hours per day should see it pretty much full again.
You should have no worries what so ever with a 120W panel and an 80 A.H. battery.
smitty_r51
I went 60ah lithium. ..Lot lighter and smaller, charges off the alternator out the 120w panel fine ...Haven't ran out of juice on it yet so can't tell you how long it lasts but it did three days fine without starting the car (fridge, leds and kids tablets)
