To work out how much will be put back into the battery from solar is relatively easy.
Lets say you have a 100AH battery and use 30AH per 24 hour period. (as you have said)
You will normally get 75% to 80% effectiveness out of a solar panel. 80 watt panel at 75% effectiveness equals 60 watts being generated.
60 watts divided by 12 (which is how many DC volts in the system) equals 5
That is 5AH put back into the battery every hour.
Assuming that every day is sunny, and that you adjust/move your panel to face the sun every couple of hours or so, you might realistically get 6 hours of effective sun per day.
That means 6 hours of sun per day multiplied by 5AH equals 30AH back into the battery.
In this scenario, you would effectively replace everything you use. That is assuming optimum conditions with everything and no cloudy, overcast or other days where the panel isnt moved around etc.
For info, I have an Engel 40 litre fridge, LED lighting and charge the odd battery for the camera, phone, iPad etc and use a 120 W panel. Usually after the 3rd or 4th day, I notice the temp in the fridge creeps up a bit. For a long weekend trip I wouldn't worry, but for longer trips I will run the generator for a few hours and hook up the 7 stage battery charger to teh 100AH battery which reconditions and charges it back to full. During colder weather, this period can stretch out to 4 or 5 days, but then you also dont have the sun for the solar like you would during the hotter/summer period.
Bit long winded, but hope it helps
