solar battery charger
jacnden
hi all
for various reasons i only have a small battery as my second battery and usualy only run my fridge of it. after 12-24 hrs it flattens the battery if i dont run the car
i have been thinking of getting a solar panel to connect via clips to the battery to use while i am camping
can anyone recommend solar panel ( wattage size etc.)
i see quite a few available but not sure what to get for my requirements
dennis
jacnden
the fridge is a waeco cdf35.
from searching the net it seems it draws about 3-4 amps and the battery is 60 amp/hour
i am looking for something that will keep the battery charged without overcharging
dno67
The size of the panel will have no effect on overcharging your battery. That's the job of the regulator, so look at panels with a quality reg from sellers with good feedback.
With solar IMO biggest is best, so it basically comes down to what size panel can you carry with you.
jacnden
thats interesting, i dont know a lot about solar.
so i could have a 10 watt or a 200 watt panel and the regulator decides what charge goes to th battery?
Hi Dennis,
Ideally the best scenario will be a regulator that is separate from the panel so the regulator can be mounted close to your auxiliary battery. Also, the best type are MPPT regulators but can cost more. Ultimately this will become an exercise in economics where you will match the gear you buy with your needs while spending as little as possible.
Are you able to provide some guidance as to what you would like to achieve and we can fairly easily recommend some gear for you to look at.
Jason
hiluxdriver
I was looking at this very same option a little while ago as my second battery is also quite small. I was initially going to permanently mount a flexible panel under the mesh of my roof cage, but others advised there would be too great a loss in power due to the obstructions. So I am now sold on semi permanently mounting a solid panel to the roof cage for extended trips, basically as big as I can get without going over the edges of the rack too much.
There are different types of solar panels too mate, folding (portable), solid, flexible, sheet ect. So I guess decide which type you want, then get the biggest one you can for the amount of money you want to spend.
jacnden
my plan was just to put a panel up when i set up camp.if i am moving every day its fine its only when i sop for 2 or more days
campingtechaust, jason i sent you a pm
