muc the truck
Over the years I must have met 50 people thinking there drum brakes were fine with brake fluid laying under the dust seal , just along as it was not out side . and have just seen it again on this forum.
THIS IS SO WRONG .
there are two seals at each end of your brake cylinders . the inner seals hold all the brake fluid inside away from the dust seal that you see from the outside .
WEAR SAFTY GALSSES
Now you need to pull back the dust seal and look inside , it should be clean and no brake fluid in there . if there is brake fluid in there it often squirts you in the face when you pry the dust caps back . If this happens your well and truly on borrowed time as your rear brakes just lay dormant not assisting the braking at all .
see the photo. there should no be a drop of fluid behind here.
THIS IS SO WRONG .
WEAR SAFTY GALSSES
