Snatch strap use
gqjim
I hope this is the right place to put this information but after recieving it I thought many of you may be interested to keep yourselves and others around you safe when doing any type of recovery.
Coroners report about a fatality in Tasmania involving the use of a snatch strap.
The report is in the public domain.
This is a summarisation of the report below and have left out most of the names and places and abbreviated the vehicles involved to Toyota ute and Landcruiser for easier reading.
I, (the Coroner), Find That Mr Stein died on or about the 3 October 2009, aged 18 years as a result of a Traumatic Head Injury.
Circumstances Surrounding the Death:
… the Toyota ute became bogged on a side track. A Landcruiser manoeuvred into position with the intention of towing the ute free. The ute had sunk into the mud up to its axle and was firmly bogged. A snatch strap was attached to the towing assembly of the ute; the other end was connected to an attachment point on the front of the Landcruiser. Whilst the recovery equipment was attached a number of the occupants alighted from the vehicle. Mr Stein and others remained in the Landcruiser. There was only one occupant in the bogged ute. Lighting was non-existent and illumination was obtained by using torches and the vehicle’s headlights to aid in connecting the snatch strap. Having connected the strap, the Landcruiser reversed away from the ute. During this process part of the towing assembly on the ute has broken free and smashed through the front windscreen of the Landcruiser striking Mr Stein before leaving the vehicle and landing some 90 metres behind it. The area has little or no mobile phone coverage. Team members unsuccessfully performed CPR. Both vehicles involved were examined by Transport Inspectors and were found to be unroadworthy. However, the defects identified in both vehicles would not have contributed to the death.
The towing assembly that was fitted to the ute was inspected and found to be corroded.
The snatch strap was examined and showed fair wear and tear.
Tasmania Police found that:
· The snatch strap was attached to the tow ball. Snatch strap user’s guidelines and current accredited 4WD training courses all advise that the snatch strap should never be attached to the towing ball in this type of recovery operation.
· During recovery operations using a snatch strap, all bystanders (other than the drivers’ of the two vehicles involved in the recovery) should be at a safe distance (1.5 times the outstretched Recovery Strap length) to the side of the recovery operation and NEVER in the line of the recovery.
· There were no suspicious circumstances surrounding the death.
Comments & Recommendations:
After reviewing the evidence I am satisfied that the fatal injuries suffered by Mr Stein can be directly attributed to the failure of the towing assembly. The towing assembly had deteriorated over time affecting its structural strength. I also note that there was some evidence of poor quality welding on the ball coupling. It is also clear from the evidence before me that both vehicle owners were not aware of the dangers of attaching snatch straps to tow balls when completing recovery operations.
Having considered all the material before me I recommend that the motoring public, particularly those using 4WD vehicles be made aware and reminded of the dangers of using snatch straps in recovery operations. It is important to correctly attach (following the manufacturers recommendations) the recovery strap to a motor vehicle. A standard tow ball or vehicle tie-down point is not designed for this purpose and may result in the strap or a vehicle component detaching from a motor vehicle and striking and seriously injuring or killing a person. Only attach the strap to a vehicle recovery point or device that is suitably rated for use with the strap.
Before I conclude this matter, I wish to convey my sincere condolences to the family of the deceased. This matter is now concluded. Tuesday, 28 September 2010 at Burnie in the state of Tasmania . Donald John Jones. CORONER
If you would like a copy of the full report please PM me with your email addy and I will forward it to you
Regards
Jim
Grumpy
Very interesting reading, a lot of people are not aware of the risks of these potentially dangerous missiles we use to recover our vehicles, thanks for the post.
Plastered
about the standard tow point on the front of my patrol is the Hook shape bar with a flat piece of steel to stop the strap from falling off when loose.
Is this Rated??? or Safe for use with a Snatch strap??
gqjim
To the best of my knowledge yes they are rated recovery points
PLEASE anyone CORRECT ME if I am wrong
They must be bolted on utilising hi tensile bolts though
Towie
Yes i believe they are but other vehicles have hoops & points for the vehicle to be tied down during transport & they are not rated recovery points i think its cheap insurance to replace them with high tensile & rated points.
Another note (not that i'm an expert) is that the recovering vehicle should not be reversing unless no other option is available... bad for the vehicle & puts you right out in front of anything comming your way.
Very sad for someone so young & the family/friends who were there & have to live with it & at xmas.. very sad..
jazzajess
hmmm was out the bush on weekend .
came past couple of guys bogged
snatch strap was on tow bar on 1 vehicle and the other on alloy bull bar wrapped and tied.
billolga
A few years ago on Cable Beach I saw the Council recovery vehicle snatch a Holden S.....g Wagon by the BULL BAR - Yes he got him out, but the Bull bar was at 45 Deg after.:eek: - I don't think he would have driven on the Beach again.
( From my knowledge the Patrol front hooks are rated)
banshee
i have seen bullbars come off and crash into the rear of 4x4 vehicles...no injury but a bit a mess to the rescue vehicle...ya got to be so careful and alot of people unfortunately just do not know...poor bugger down south...
jazzajess
Well i went and played for a bit then came back down the hill they were still there trying to pull out this hilux they came running at me for help so i winched it out first go then followed them to the bottle shop they got me a carton nice guys.
