Snatch Strap Comparison
hulk4x4
Hi all,
I'm sure most of you are aware of the latest comparison and testing performed by Unsealed 4x4 on some of the snatch straps on the market, but I thought it would be good to create a separate thread for anybody looking for this information in the future instead of having to go through all the comments in the general snatch straps sticky thread.
Here is a direct link to the article in UNSEALED 4X4 ISSUE 012.
It's been a few years since a comparison test on all the big brands has been done and I've got to say that some of the results are very surprising. What are your thoughts on the results? Do any results surprise you? Will the outcome of these results determine what you buy next, or are you likely to stick with your trusted straps?
It's definitely an interesting article and worth a read. I'm looking forward to hearing everyone's opinions.
I have 2 ARB snatch straps and have never used them, there about 7 years old, do they have a use by date.. Lol
hulk4x4
Hi Swaggie,
The lifespan of a snatch strap is normally determined by the number of recoveries performed and how you look after it. If they are still in as good as new condition then they should be fine. Obviously if you haven't used them then they won't have any frays or stitching problems.
However, if you have kept them in the back of your car in direct sunlight for 7 years it is likely that the capacity of the straps is compromised. Another thing to keep in mind is how your straps are stored. If you have bags for them and they are not stored in direct sunlight they should be OK. If you leave them lying around in the back of the car where you are likely to have sand and grit then it is likely that the fibers of the straps have been damaged. Your safest bet would be to replace them if that is the case.
Hi Swaggie,
Thanks mate for clearing that up, both have been kept out of the sun inside.. They are brand new...
Blue_haired_man
How many recoveries is a strap good for?
It's hard to say, it all depends on the recoveries. Any stitching starting to fail, fraying or loss of elasticity are the most obvious signs, by then they are gone. But a snatch strap will loose a bit of elasticity every time it's used, especially heavy pulls. They are after all a consumable product with a limited lifespan. Another little known fact is that straps should be rested for about an hour (from memory) between recoveries to allow them to retract to close to their original size, but this isn't always possible.
Cheers Leo
hulk4x4
Blue_haired_man makes very good points. It all depends on how well the strap is maintained and the usage that the strap is subject to.
I will add one thing though; if you do see any signs of damage be sure to cut the loops of your strap so you're not tempted to use it. And of course, replace any damaged equipment before you head out on your next trip.
Alex
red hilux
I just bought an Opposite lock snatch strap to replace the recalled one from 4wd supa centre that they wont take back.
hulk4x4
Is that the Hercules/Tigerz11 brand? They performed quite poorly, I'm amazed that they won't take them back? They were actually terrible in all aspects of the testing.
