Smart Bar vs Enviro Bar vs Steel
Hi guys,
I'm fantasising about buying a bull bar and am intrigued by the Smart and Envirobars. I've always had my heart set on a steel bar. However, a steel bar plus a winch = heavy duty suspension upgrade... I'm wondering if the Smart/Envirobars are light enough that I could get a winch compatible one, without the winch, and without the suspension upgrade, and then get a winch and do a lift later? If I have to save up for all of it in one hit, like with a steel bar, then I'll have nothing for a really long time.
Apparently they are rated as well as steel bars for crash resistance and stuff etc. Whatever I get I'll want to get it colour coded white, so that will be an issue to think about too.
Cheers,
Ben
Hi Ben
Ive added an ARB deluxe bar, a winch and duel batts and my suspension is fine and I've taken it in some remote stuff ... In those darn Hills I'll stick with steel...
Goodluck with your choice.. ;)
Kirkster72
I have the smartbar with a Runva 9500lb winch. I went for the smartbar for looks as I like it & I think it only weighs 40 odd kgs.
abw
Just looked it up..46kg for the winch smart bar fitted;) My ARB deluxe bar doesn't weigh much more than that. Really, it just comes down to personal preference. I like the look of the steel bar. Came way too close to hitting skippies a number of times, and the steel bar just gives me piece of mind.
struth
I removed a smart bar from a clients car once, they are not light...at all... in fact I reckon the weight more than most steel bars.
I am not sure what is smart about them at all,
Steel frame with heavy plastic moulded to it, a steel bar rots back into the earth, plastic hangs around for centuries, I just don't get why they are called smart.
LowLux
If the weight is not all that different then it obviously will be a cost decision. I prefer to have piece of mind but personal choice.
Ziggy
Main virtue is that they are claimed to slowly spring back after being deformed.
smitty_r51
I am not convinced on something that springs back into place... The damage is still fine, you just can't see it now... Bit like dropping a crash helmet
I went steel for the protection...if the bar gets a big enough knock to be damaged i want to be able to see it and get it professionally repaired or replaced
My steel bar doesn't even bend in a minor collision, hitting a kangaroo is minor at lower speeds, so I don't even have to worry about it springing bac... ( give me my k you useless SwiftKey) grrrrrr.
Hotdog
1 wallaby and 1 large Grey kangaroo and I'm happy I had a lump of ARB steel on my nose. Both hits instantly fatal and both times the animal got deflected under the vehicle and not over.
Aaron Schubert
The steel bars aren't that heavy anyway - I'd say the one on my 80 series is about 30 - 40kg? I could lift it myself without too much of a problem. For protecting the vital components (IE radiator etc) I don't think you can go past steel
Aaron
Silver76
Steel all the way. Purely based on looks. The smart bar doesn't appeal to me at all. Comes down to your personal preference.
Ziggy
Aaron
ECB told me that steel bars are around 80 kg but they don't make em so maybe don't know.
It's interesting that most vehicles sporting the Smarbar that I've seen have been from public authorities, shire councils and the like. So some purchasing officers have been doing evaluations that they're accountable for. Something to think about.
struth
Or the manufacturer is offering attractive fleet deals
