Slarty's adventures
He did post something in the past day or so, but has been very quiet.
Did he get to the meet up ?
If so, I imagine he went ok :D
80lover96gxl
Think I saw it at a work shop on osullivans beach rd today, getting that head looked at id imagine.
Sent from my GT-I9505 using Tapatalk
rogerazz
Being an old Chrysler Charger man from back in the 70's , can't wait to see some later models.
Still drive Chrysler/Mitsubish.
Loved the old Mopars.
Slarti can show me over his rig maybe?
cookie64
The car was obviously not well when he bought it and I think that the person who sold it would have known that and Slarti even had an RACV check done but they only picked up / reported sh!t stuff.
It has an overheating issue which became evident when he went to go on Billy Goat and he had to turn around half way up to the Helipad.
He tried flushing it several times to no avail but he stayed after we left going off with his relatives in their 4wd so not sure what happened after that but I do hope that he & his family got back OK.
It made me quite angry that the seller did that to someone knowing full well that it had issues, I think the guy belonged to the Jeep Owners Club as it had a Jeep Jamboree 2010 sticker on it so yes he was / is a fellow 4wder.
May Karma wreak havoc on that person
cheers
Lays4B
I think he was taking it to the mechanic last Friday to have it checked over. He should have an update soon I would say.
Slartibartfast
Yeah, not much to report just yet I'm afraid.
I dropped the car off to "Down South Car Repairs" (on O'Sullivan Beach Rd) on Friday and am expecting a diagnosis sometime this week. At this stage I'm hoping it's just a blocked radiator. After speaking to several people about it, including the mechanic, a clogged radiator seems to be the most likely candidate, the main concern is whether the blocked radiator (and subsequent overheating) has led to other issues.
As it is the car drives perfectly fine on the flat. We drove it all the way from Melbourne to Dargo (about 4 hours) without any signs of overheating. The needle stuck on "half" the whole way to Dargo, but once we started climbing the hill the other side of Dargo the temp started rising rapidly. We had to pull over half a dozen times to let the engine cool down before we reached to top of the hill. While the hill is admittedly pretty steep it is none the less a regular sealed road and any decent four door sedan should be able to climb it without incident, let alone a late model 4WD. Once we crested the top of the hill the temp was perfectly fine on the dirt track along the ridge top and down McMillans Road into camp.
At camp we tried all manor of things to diagnose what the problem was including checking operation of the fan, "burping" the radiator, dropping the thermostat into a boiling billy and finally running a flushing agent through the radiator, all to no avail. After each attempt I took the car for a run up McMillans track (which is a steep 3000' climb) and like clock work, as soon as we started climbing the temperature would start to rise. Once we'd climbed 600' or so the car would over heat and I would need to stop, wait for the temp to cool down, then turn around and head back down. It became apparent fairly quickly that we weren't going to be able to drive any tracks, so the Jeep spent the weekend camped in the bottom of the valley while we piled into other peoples' cars for a little wheeling. When it came time to leave we drove out via "Conway Track" (so as to avoid the 3000' climb) then drove all the way back to Adelaide without incident, so it's really just a problem when the engine is under load :confused:
The car is 6 years old and has only been driven 60,000 km. According to the manual the coolant isn't even due to be replaced till 120,000 km, so it is a little perplexing that the radiator could be clogged already but we can't imagine what else it could be.
I'll let you all know when I have more details.
Slartibartfast
Anyway, here's a photo of her in our driveway:
billolga
Slarti, they are the same symptoms I had when I was heading to Grumpy's place before O'Tooles 2009 trip. Grumps suggested the local Radiator guy at Morwell & for $150 I haven't had a problem since - Here's hoping.;)
mitschal02
What a bugga :(
If the previous owner did know about the problem hope Karma bites him hard :mad:
Keep us informed Slarti. Ours was doing exact same thing a while ago turned out to be blocked radiator and the clutch fan needed servicing.
Do the Jeeps have a clutch fan ??????
Slartibartfast
I'm not sure about all Jeeps but the Wrangler has an electric fan, and it it is definitely working. Damn near sounds like it's about to take off when it gets hot! It's a good digestion though.
Another suggestion has been that possibly the water pump isn't functioning as it should. Again it would seem odd for the pump to pack it in after only 60,000 km, but it had to be something???
logitech
Its not the k's you should worry about mate, belts and electrics all perish with time, thats why the service scehdule is always 10000k's or 6 months, what ever comes first.
Good luck with the mechanic, from what i read the radiators can fill with crap from the casting material from when the engine block is created. I can't see you being off the tracks for to long.
millsy
Did you try a new temp sensor in the thermostat housing. Or wherever it is located. A bit of a long shot I suppose, since your gauge actually shows a rise in temp in those climbing situations, which does make sense.
My Patrol developed a temp 'issue' when the dashboard gauge suddenly moved to a comletely different position for no apparent reason. A much higher reading. But this was under all driving conditions - flat and climbing, cool weather and hot weather. I finally got round to fitting a new 'sender' (about $20) and it went back to its normal position.
There could be the possibility that small increases in your temperature, when climbing those hills, are causing a much greater change in the resistance value of the resistor in the sender than normal. Thus giving you a much higher reading on the dashboard than normal.
Are there any other indications, from under the bonnet, that the motor really is as hot as the temp gauge indicates? Bit hard I suppose, unless you can actually hear boiling 'gurgles', or see or smell steam vapors escaping the radiator cap.
darb
don't shoot me down here, but maybe the seller didn't know ... and maybe its not load related, but angle related?
at a certain angle the engine is developing an air bubble or some other machination causing the engine to overheat? Not being a mechanic myself I don't know if that's a silly suggestion or not ... but as you said it seems to be up a steep hill ... what about on flat soft sand? (sand is VERY load intensive on an engine ... but no angle). Or driving on flat gravel in Low Range with some high RPM, low speed, maybe towing something heavy (again , forcing load but not angle).
I often wonder about engines on extreme angles (i've been in a few bogs where I've wondered if oil still gets around the engine correctly).
Slartibartfast
I'm pretty confident it really is that hot. You can see heat rising off the bonnet and when you open the bonnet it "smells" hot. I also did one test where I drove up the hill with the radiator cap "on" but not "clamped". The car got to the same point on the hill (approx 600') and instead of overheating stream just started pouring out from under the bonnet. I stopped, let it cool down a bit then headed back to discover the overflow reservoir was almost empty. It seemed the boiling was preventing the water from getting too hot, but given the amount of steam billowing out it sure didn't look like would last long ;)
