perfect, u only use them when u go wheelin! mine r the same and have had current 1's for aroung 2yrs with about 80% left.
balancing...... every 1 has their own ideas. you must remember with a tyre as aggresive as this, if u loose sum rubber in the bush, its like taking all the wheel weights off..... masive wheel wobble!.they r a pr^*k 2 ballance, looking at the side of pk's rims i swear their is less lead in a tackle shop! i dont have the luxury of traditional balancing as i have external beedlocks, wot i do as ive been asked plenty of times while out 4b ing is put around 1 shot glass full off 3/16 stainless ballberings in each tyre before fitting the outside ring.
works a treat and never had a drama with balancing.
so long as u dont want 2 drive across the state with them.,they will last a long time.
if u do have 2 drive a fair distance before u hit the bush then i suggest u run aroung 25-28psi. by the time u get 2 your fave bush trak, they will b around 32-35psi
they r an awsom tyre and run @ the right psi you will b amaZed wot they can do!
good luk, cheers 345 chippy
