Show us your handy work!
Bainsy
Hey guys, i thought id start up a thread where you can show off your handy work! show us things you have constructed by yourself for your 4wd, such as rear draws, consoles, bar work ect as well as installations like winches and radios. if u have made or installed it yourself, throw it up!
Grey Ghost
Something like this Bainsy?.....
My camper spat a wheel bearing cover, twice, on the Gawler Ranges trip so I used what we had on hand to keep the sand and the grease separated.
oznog05
Hi Bainsy,
I'm doing rear draws for the Hilux. So I will post some pics as I'm going. Should be finished in a week or two.
1 red gu
here is a few things i have done in the shed over a few beers
made the cargo barrier and draws also a sub box that fits between the back seat and straps for the baby seat
done a full rebuild of the camper including new tent,kitchen, pull out bbq, two 100ah batts on the draw bar ,the spair tyre is on full hub and bearings so it is a easy fast swop over
also big thanks to a member of this forum for all the gas work for the bbq and tailgate kitchen:D:D:D
now in making rock sliders and scrub bars will post picks when finished:D
Bainsy
modded bullbar for better approach angle
also installed a warn highmout winch, recovery hooks either side. modded light mounts to fit the lightforces better and added rope loops. also welded in new antenna mounts
1 red gu
made this trailer to carry all the bikes when we go down hill'en works great to:D
Bainsy
i smacked on a turbo and ported manafold. custom built garrett roller bearing turbo built by JPC
Also made my own exhaust system
Got a blank when i got the turbo and cut the hole basicly the same size as the gasket, pressed in 3" pipe and welded it in
got some 3" bends and straits. cut and dummied it all together with masking tape and welded it all together
Bainsy
nice work bainsy
thanks, im not a welder or nuthing either i just like to have a play and learn as i go along. got tonnes more aswell but thats enough for 1 week! you done a nice job as well. those draws came up great and the trailer looks good.
Alien d2
My dash mounted "Engine Saver",
Had to make a heat sheild after fitting a longer 2'nd battery and modifing the tray,
:D:D:D
CHUAH
Only a home made job, but it does the job.... :D
THE 200
picture of the trailer my old man brought like 15 years ago all so has a boat loader as well .. its gone around oz and a lot of trips away so i have decided to put a new floor in and new paint job same as the 200 and new set of wheels and i em planning on putting a trailer top tent
Artie
Just found this thread , awesome job guys . Mods look great . I've done some of my own , i was given some shelves for the back of the cruiser & i modded them to suit my needs. Had to cut the bottom shelf to fit the cut down sub box . Then built a draw for the bottom which is angled to suit the wheel arch . Also made a winch cradle for the winch to suit a non winch alloy bar .Also turned an old steel gate into a roof rack to carry my spare wheels when we get away 4byin . I'll get some pic's soon & put them up on here as soon as i work out how :eek::D:D
Next on the list is a fridge slide .
Cheers Artie :D
