Shocking Fuel Economy
MawsonSnow
Hey,
I have a MY02 jeep grand Cherokee 4.0 inline 6 and my fuel economy usually Sits on 10l/100kms,
But as of the weekend strictly driving on the highways on 110kmh my fuel economy has shot up to 18-19l/100kms even at idle its using 7lts per hour when it use to be 1.9 per hour
I've changed the air and fuel filters and o2 sensors and flushed the fuel system and filled up with 98 again but it's made zero difference..
So I checked for error codes and nothing came up.. so I reset the computer and took it for a long drive and only managed 270kms to a 90lt tank......
It's not running rough and not leaking anywhere and doesn't smell rich..
So I'm at a total loss on where to go next
Any ideas??
MawsonSnow
Cheers Luke, didn't get the chance to do that as the jeep died this morning grrr :( the 3 month old fuel pump died and when I took it out there was a lot of gel like substance in the strainer... So I'm Thinking it must have been bad fuel that was killing the fuel pump causing the fuel economy..
Just have to wait for a new fuel pump from mopar in Canada to get here overnight
MawsonSnow
rof lol aust post can't do that between Mildura and adelaide :rolleyes:
hope the crappy fuel hasn't done any other damage :)
Haha yeah, mopar in Canada put it on the next flight for a nice fee hahaha
But I'm hoping it hasn't done more damage
nightscale
Sounds like somethomg in the fuel tank to be gel like. Id be taking the tank out and cleaning it
Sent from my SM-N9005 using Tapatalk
MawsonSnow
Yeah tank is out at the moment getting cleaned and dents removed while its out.
Just picked up some brand new injectors while I'm replacing everything..
monbeg
I'd be publishing where you got that fuel too, assuming that was the culprit.
Might save a few others the same fate.
ULost2
talking about stuff in the [truck] fuel tank. The driver said the truck would go well and then start to die, then pick up again and be fine for awhile the die again and so on. No one could work it out so we went fishing with a bent up bit barb wire. Didn't catch any fish but a bit a rag was hooked and loaded ;)
and btw; mice don't go through the fuel system too well. refueled an R600 mack out in far sw qld from drums of fuel!! Sort of blocked up the filters a bit. At least it wasn't too much drama with those old donks.
MawsonSnow
Update..
New fuel pump and injectors in with cleaned and flushed tank.
New filter and 98 petrol done 160kms highway driving and went through half a tank again...
So I went and cleaned the map and still no difference
I guess it needs to go to the dealer for a full inspection
So its off the road for a few months till I can save up
Gareth4x4
Maybe you should put it on a dyno and see what the Air fuel ratio is at idle, cruise and WOT. Could highlight where its using the excess juice.
MawsonSnow
Yeah I may have to when I get the funds lol
Any good 4wd dyno shops around Adelaide?
I only know of Keen Dyno Edwardstown that advertise 4wd dyno down south.
There's bound to be one or two up north somewhere I'm sure.
Sent from my HTC1 using tapatalk
bally
Banned
your definitley reseting the computer properly and are 100% sure your using that much fuel and that the gauge isnt lying to you??? i cant imagine how you couldnt smell petrol when using that much..........
MawsonSnow
Yes...... If it has a 78l tank and I've driven 160ish kms and I have to put back in 41lts of fuel the tank I think the gauge isn't lying.... I'm not stupid mate
underdog
Nobody's saying you're stupid? I know people who aren't even aware that method of calculating fuel usage exists. It's easy for anyone here to assume that we know 100% what's going on at the poster's end, but much safer to confirm. My fuel gauge is 90% useless once it gets to 1/2 tank, but even in saying that I still wouldn't expect anyone here to know that I've gone out of my way to confirm that's the case.
Unfortunately I don't have any experience/suggestions to offer you mate, but I've read most of your posts lately and I hope it all works out for you. I'm in a similar boat, and facing the possibility of not having a 4wd to enjoy pretty soon; so I hope you can get yours up and running and enjoy it sooner rather than later.
muc the truck
while the tank is out consider getting the tank bottom rhino sprayed . I have seen a couple done and they resist rock damage well .
warlok
just by chance have you ever used ethanol fuel in your vehicle as I have heard in some cases it can form a gel like substance that blocks fuel filters & injectors if the vehicle has not been properly manufactured for it
