camperman2010
Got the Jackeroo back from the mechanics today after 3 weeks with no conclusion to the problems. I will start from scratch hopeing someone might have an idea.
When the car is cold, it's hard to start,( on both petrol and gas ) it cranks over and over before it starts, but when the car is warm or just pulled up from a drive it will start with no problems, but if you wait 15 minutes or more, it just cranks over and over before it starts again.
Below is a list of what has been checked and changed.
1996 Jackeroo 3.2 Ltr petrol/lpg
PCM Module : OK
ECM : OK
Injector Pulse : OK
Spark : OK
Fuel Pressure 45 psi on cranking : OK
Throttle position sensor cleaned and tested OK
Fuel Injectors cleaned and rebuilt
Changed all relays and fuses
No fault codes
Relaced the following.
Fuel pump,Fuel Filters Fuel lines, Fuel pressure regulator, coolent temp sensor, New Spark Plugs and New Leads,New Lpg Converter
New Air Temp Sensor,New Battery, New Alternator,
New Map Sensor,
Im at a loss as why it cranks over for a long time when its cold before it fires up. It really doing my head in. anyone with any ideas ?, at this point i dont care if you throw me stupid question or thoughts, i just need help.
PCM Module : OK
ECM : OK
Injector Pulse : OK
Spark : OK
No fault codes
New Map Sensor,
