You'll always need to top up these mats with a couple of breaths as the self inflating part is only the foam core inside the mat returning to its natural shape. Depending on the quality of the mat this might be less that the "full" capacity of the mat. Regardless, the foam is there to insulate you from the cold ground not provide support.
As others have said, when you get to camp roll it out and undo the valve. Leave it for a few hours, and then top it off with a few breaths. Try not to get too much moisture into the mat as you're exhaling into it. Also, you'll be more comfortable if you dont inflate it rock hard--it should be just enough so that you find enough balance between letting it mould to your body and. It compressing the core too much so as to detriment insulatin property.
