saving moving map track log?
neville lowery
Just wondering if anyone can give me some tips,
When I clear track tail on the moving map drop down menu, I am losing tracks that moving map made,
I am sure i saved them and gave them a name etc and they appear to be saved as a plt file in data but when I go to load them back up onto the map they were made on nothing appears.
How do you save your moving map track tail as a track?, Should I be leaving the "clear track tail" option alone.
billolga
Why are you DELETING the Track before you save it because that is what "Clear Track Trail" does?
SAVE FIRST!
neville lowery
Thanks for the reply Billolga
I thought I had saved them.
I am pressing save up top on left of screen,then selecting save track to file,the data box opens and I name it and it is in data as a plt file, I am also pressing the smaller save all files button on right side at top of map, but after clearing moving map track tail nothing appears when I try to load the saved plt track file.
I got one to save but I had manually created a track and added to it.
Its getting to the stage where I will have to "trace" the moving map tail with the manual create a track option and then save before clearing moving map track tail.
Perhaps the "save track to file" is only for manually created tracks? If so hows everyone saving the moving map track tail as a track for future perusal?
Its probably just something Im doing wrong in the save process but I cant see anything else to try.
Thanks in advance for any help.
4X4
When you open the track file are you opening it as an active track. Open the Track Control and make sure the track you load is Track 1.
neville lowery
The track I load is showing as track 1 on right hand side above map, but no track appears.
Could it have something to do with deleting the daily track file log? I read somewhere it was a good idea to delete these regularly to save congestion in data.
I will try renaming the daily log and saving this as well.
I have opened track control and there appears to be nothing there in the window.
I will have to learn more about using the track control feature.
4X4
On the Toolbar click on the Moving Map button. From the drop down list, select "Copy Track Tail to Track 1". This will save your track as the active track.
PJR NSW
Banned
I only have the WinCE version in the car but this works for us. I do not delete the daily track files. I never use the Clear Track File function. I keep all of the daily track files both on a trip and even back in town.
Every now and then I move the whole lot to the house computer into the full Ozi directory and then delete them from the car. On an irregular basis (when I remember or think of it) if I am not interested in what happened I then delete them. They do not take up that much room and its handy to keep them for a few months in case I get a speeding ticked that I want to challenge.
Naturally those for a trip that I may want are moved into a folder on the home PC with the trip name on it. Unless it is for a special purpose I do not change the file names. However if I combine a whole bunch of daily files I will give the final track file an appropriate name. Sunch as The Kimberley June 2020 etc.
Phil
