are you going to keep the rear end leave or convert to coils?[/QUOTE]
The d22 I'm looking into belongs to a mate, it's a ripper truck that has had a fortune spent on mods so far and he loves it, it's just on its limit suspension wise now. For rear suspension I wouldn't mind looking at a five link coil set up to try and save the camping gear being smashed to bits on the rough stuff.
The fabrication and set up side of things is no issue, the problem is finding an engineer with the courage to sign it off. A bloke I know rang around for an engineer to certify his gen111 conversion in a gu and got told because he'd changed the weight over the front axle of an air bag equipped vehicle they didnt want to know about it. That seems a bit weak when you consider bullbars winches and batteries, every airbag equipped tourer is illegal. When I put my 60 chop and v8 through the engineer was hesitant on the phone given the amount done but when he saw the work was to a high standard he loosened up a bit.
I think the easiest way to do this job is to get the correct width diffs with comparable steering from a similar weight vehicle which should take a lot of guess work out of it. If all that has been altered is the mounting I'm hoping I can find an engineer with the ticker to look at it.
