Sand Driving Tips = )
unit
Hi all,
Thought I'd ask a noobi question...sorry if it's already been answered...
Heading away this weekend and will be driving on Sand for the first time.. Just wanting to see what people advise for first timers on sand...?
Planning to drop PSI to 18 and also have some MAX Tracks and a shovel in case we get stuck. Will also have the basics in terms of recovery gear. No bar or Winch, though, i can't imagine there's a lot on a beach to Winch from = ).
I have discussed with a few experienced 4x4'ers who have told me to just keep a consistent throttle, with good momentum n try to stay on the harder sand.
Is there any other tips from experienced Earthers.. We'll be driving Wind Woppa Reserve, Port Stephens NSW 2324
smitty_r51
Sounds like you have the basics
Don't stamp on the brakes to stop. ..Let it coast if you can .
Don't turn out go across sand dunes
If you have any stability control or dynamic setting that stops the wheels spinning in the wet turn it off otherwise you get nowhere
Have fun
Wash the salt off afterwards
Toddyh
I believe the driving there is fairly simple so should be a good place for a first timer. Couple of tips in addition to what you have already mentioned.
Don't stop suddenly. Always coast to a stop if possible.
Try to stop facing downhill so it's easier to get going again.
If you start to bog down avoid planting your right foot as you will only dig yourself in deeper. Instead stop, assess the situation and either start digging, lower tyre pressures (should be able to go to 10psi for brief periods), start a recovery or a combination of all of the above.
Start at 18, if you're having trouble still then try lowering to 15, or even 12 etc.
Stop when it is obvious you are losing momentum, don't go hell for leather and go down to the axles.
You might need max to get out if really bogged, but then with lower pressures you should be better placed not to be a problem.
Don't go over say 40ks, and don't turn wheels sharply cornering etc.
Assuming this is beach driving, go wheeling on the outgoing tide.
unit
Thanks, Les, Todd and Smitty exactly the sort of feedback I was hoping for ... :)
Judging by the replies power is not the key here when driving on sand, would you recommend 4L or 4H ?
The one thing I don't have an was considering picking up today or tomorrow was an air compressor to air up post sand excursion ...
I'm running coopers All Ts, if im driving at 18 psi im betting it's far too low to head on to tar mach again n search for the nearest servo ...?
phs
18 psi is still rock hard believe me it is
depending on your specific tyre it may be ok
But not recomened
Cornering will be your problem
Esspecially if speeds are above 60km/h
Best you air up prior to road driving
For sand I start between 12-14 psi
If it looks hairy and soft I go 8psi
Once again depending on you tyres / rims ect.
Hard to say if I would go below 16psi
Toddyh
4L or 4H will depend on conditions. If you find it hard on your clutch in 4H then stop and go to 4L. If 4L seems too slow then stop and go to 4H.
Tar is not the enemy of low tyre pressures. Speed is. Provided you can go slowly enough to the nearest servo you can drive on tar at 10psi if required. Obviously an air compressor means you can air up straight away and drive quicker on the tar.
I had an auto Hilux and 4 low was better in most situations it pushing soft sand. The Hilux auto transmissions have a tendancy to overheat when working them hard. I fitted a transmission cooler and that sorted it out. Cost about $140 from Repco etc and can fit them yourself if you are a bit handy.
You are also better to take it out of auto and manually select a gear as it locks up the torque converter better and generated less heat.
DEFINITELY get yourself a compressor and a decent tyre gauge before you go. You need to be able to accurately know your tyre pressures to understand what is going on and not be afraid to lower your tyre pressures
Driving on the road with low PSI can ruin a set of tyres real quick so better to air up before leaving.
I had my Hilux on Coopers as low as 9PSI on Stockton in the soft stuff
Ziggy
The two keys to progress are tyre pressure and momentum.
For dune driving don't get sideways! And when going down if you see the sand moving faster than you grab some more throttle.
Ziggy
If the beach is firm not much skill is required.
The greater the slope to the water the softer the sand will be.
unit
Thanks Albynsw, Hilux is a manual so all good on the overheating side...
sounds like a compressor might be the way to go .. will try and pick one up tomorrow before we head off
Cheers for the tip on soft sand Ziggy I was wondering about that.. I have noticed when walking on the hard stuff it can get real soft and sink real fast without warning...figured id just stay on dry hard sand ...
Thanks again to everyone... massive help and some great points on here...
unit
Sure thing..Will have some GoPro footage as well, though not sure i can post it on the forum.
Will post up photos though and a report for sure..... probably of me digging us out of a small canyon :) ;)..
@Ziggy what do you mean by 150 I per min.. ???
unit
ahh makes sense ...i was looking at the TJM portable air compressor as its 75 buks off atm ... ($185)
... better keep hunting as its only half that at 72lt per min... though i would have thought the lower the air out put per min the longer it takes to inflate ... is that correct ??
Toddyh
that's it. But as mentioned anything less than 150L/min is a pain with 4wd sized tyres.
Ziggy
Yeah, that's right.
Taking your tyres from 16 to 36 needs a bit of huff and puff ;)
Dont get too carried away with the quoted rates as the suppliers all lie.The flow rates are usually quoted at 0 PSI.and the flow rates vary with back pressure.
I have found a quality 72L/M unit will be as quick or quicker than a cheapy 150L/M so that TJM one still may be ok.
The smaller units will take longer to inflate but will still reach the pressures you want.
If buying from Repco etc the Projecta Typhoon gets good feedback as a cheapy in the comparos. Dont have one myself but they sound reliable with a decent warranty.
Regardless of what compressor you choose still get a seperate tyre pressure gauge as the compressor ones are useless I have found.
phs
I have an oppisite lock tuff green portable compressor
4 big tyres from 12 to 30 psi only takes 10 minuets
Better yet you set it up at the passanger door and the lead gets me to every tyre on my 79 with out having to move it
was about 200 bucks works great much quicker at pumping up tyres than my less than average flowmax iron what ever junk I had .
