S.A. Xtrail says HELLO!
BigblackTrail
Hi all!
So After using my XTrail as a "Toorak Tractor" it is time to hit the sand.
I have been on dirt roads in the Xtrail and up the river (Mildura area) but this is the first time on sand.
I know the basics... let tyres down, comit - dont hesitate or else u lose momentum and dont do 3 point turns on a hill... just reverse back to get down.
I am doing Canunda National Park... Any tips, how will the Xtrail go?
2003 Xtrail - Ti-L
smickbus
Hi B.B.T., good on ya for having a crack in the xtrail. one of my mates has one and tows a camper everywhere. I think you will go alright. as you said let the tyres down, i start at around 20psi and if i get stuck i have gone down a lot lower,around 14psi. dont turn too sharply though with low tyre pressures or you may run the tyre of the rim! Best advice i received in regards to sand driving is to "drive it like you stole it", give her heaps to get up the dunes but back off if you lose all forward momentum as you will only dig yourself a big hole and may have to dig yourself out. turning the wheel side to side can also help find a bit of extra traction at the top of the dunes, but only if you are going slow, not recommended at high speeds!! enjoy the trip, its a lovely bit of coastline down there.
BigblackTrail
G'Day smickbus!
Cheers for the feedback... Do I need to buy maxtrax and do I need a tyre pumer upper? :) Or is there a pump up place at Southend? - scuse the ignorance?
I'm assuming with the long weekend there will be others out there playing in the sand - so no need to fork out for maxtrax?
Dave
Alien d2
Welcome to 4x4earth:D
My neighbour just picked up an X-Trail too.
He did some reseach and said to always lock the transfer box for any sand work, they will over work the internals if you don't.
Droping the tyres to 18PSI to start with was his other comment.
It was also recomended to rotate the tyres every 5,000KM to maximise driveline life.
Have fun and don't forget some pictures for us:D
BigblackTrail
haha oh gosh... what's a transfer box?
I have read that when in 4WD LOCK mode you can only do 40kph as the <something> overheats... Apparently just leaving the Exy in "Auto" 4WD mode works well...?
Dave
Alien d2
Dave
Hey Dave,
The transfer box simply transfers the drive to both the front and back wheels.
The drop out thing was mentioned.
I thought the over heating was when in loose terain(like sand) because of the different speeds of the front and rear wheels, due to slipage.
It's new to him too and the test is next week when I'm doing a week long run with him.
I'll confirm with him when I see him next about what he found for the settings, tomorrow hopefully.
4wdsupplies
Amate of mine has an xtrail and we did the robe to beachport run with him, I had to skull drag him over a few sections but all in all I was very impressed.
