righto here we go lol the cheap and easy way to do a decent job that will last, ( i have pic's here i will post up of my old ute that i done in 18hrs, no shit )
its easyer to remove the tray, front bar, etc so there is less masking up.
give the cab a good wash down ( without soap ) then chop the whole cab with 240 wet, this will get any shit that may be stuck to the paint, make sure you keep the palm of ya hand flat also, then just give it another quick wash again without saop to get the old paint sludge off then let it dry in the sun or blow it down, look for and shinny spots, if there are any they will need to be rubbed as they are spots you have missed. then wask the sludge off again. once there are no shinny spots mask up then give the cab a wipe down with prepsol ( wax & grease remover ) then your good to go with the primer, try and use hill fill if you can but it doesnt really matter its just that high fill will hide any stone chips/scratches. Acrylic drys very quick so throw a dust coat over it 1st then start to lay the 2nd coat down a bit heavier and by the 3rd coat you should be able to lay a really nice wet coat down, then try and lay another really wet coat down about 10-15mins after. then go and have a beer or 2 maybe 3
by now it should be dry and then just chop it with 600wet but dont use it wet, going in a circular motion all over the primer ( be carfule near the edges ) then blow it down and prepsol the primer again making sure it is clean then your right to throw your base on, same as the primer, 1st coat just dust it, dont go for coverage then a little bit more on nthe 2nd then on the 3rd start to lay it down as wet as possible without getting any runs, then throw you clear straight on top of the colour even if it is still wet, the base will pull some of the clear in and then by the 3-4th coat of clear your done. unmask it in about 1hr or so then find a spot and push you fingernail in to the clear to see if its hard ( do this on the back of the cab where you wont see it if it leaves a little mark ) if it is hard you can chop the peal out with 1200 wet buff & polish or skip the buff part and just polish.
if none of this makes no sence let me know, and i will post some pic's up of some quick " lick & stick " jobs i have done. my old HiLux i did in 18hrs still looked the same as the day i did it 6 yrs before
and cost stuff all
