Being peak season and a very popular spot robe is normally fairly packed out that time of year.
In saying that tho you can still find area's to camp through out little dip conservation park and the beachport cons park, there are also areas throughout the entire dune systems, apart from the micellent buggy club area where you can find your own little spot to camp.
A couple of important things you should be aware of is when traveling the beach and dune tracks a sand flag is of utmost importance due to all the blind crests and corners, there have been many many close headon's down there from people not being able to see around cnrs due to the high vegitation making it almost impossible to see on coming vehicles.
15 -18 psi is a good pressure to start with tyres but dont be affraid to go as low as 12 psi if needed, we've been down to 10 psi on some occasion's due to the softness of the sand just to get vehicles thru and avoid boggings.
If possible try to travel with another vehicle or be capable of self recovery like having a set of maxx traxx or treads and make sure your recov gear is in good order as there's a good chance you may need it.
Set yourself up a base camp and go exploring from there as towing trailers thru the dunes and on beaches will only over work your truck and make the likely hood of needing recovery much greater.
Erringtons beach is the most notorious beach and know for its super soft sand and it's ability to trap the unweary driver so be aware of the tides and stay off the beach at high tide.
Check out a few of the trip reports in the sa section , there's plenty of good pic's, info and advise there and a good read aswell.
Robes an awesone spot and you'll have an absolute blast down there, just use your common sense and you and your family will have a great holiday.
Hope this helps.
Oh forgot to mention, the seafood at robe is sensational so check out a couple of seafood shops and the pubs pretty good to.
Sent from my GT-I9505 using Tapatalk 2
