Ridge Ryder Winches on Sale - SCA
SMOKEYR50
Hey guys
just thought others might be interested in the Ridgy Ryder 12,000lb Dyneema rope winch on sale at SuperCheap at the moment.
It's 50% - so $958 down to $479.
I picked one up today and plan on installing it over the weekend in my ARB Sahara bar.
It's my first winch so going to be a bit of a learning curve. Seemed like a good price point to start at though, and I have read good things about these ones (could only find one story on a failure).
Ridge Ryder 12,000Lb 12V 4WD Recovery Winch - Supercheap Auto Australia
Croozer
Great for a cheap winch mate. I have had one for ages a few little tweaks and they are a good unit :)
SMOKEYR50
Oh yep, what tweaks do you recommend (I'm guessing any changes will be easier while it's still sitting in the box). Probably don't want to do anything that will void warranty though....
Biggsy
Its the same as a Tigerz grande/Roo winches. $479 is a good price, $495 from tigers
For a extra $220 Folks can get a Runva winch which is Far better winch..
Croozer
I pulled apart the control box and upgraded all the electrics and mounted it up under my bonnet also split the drive unit and sealed it better.
If it your first winch it will be fine. The unit should be fine how it is. ;)
I got mine on a fathers day sale for $350.00
SMOKEYR50
Got the winch in the bar in about 30 mins. Spent the next 3.5 hours trying to find somewhere to mount the control box. No result yet. Not a lot of room in a Pathy engine bay!!
SMOKEYR50
At this stage my two options are to mount the control box down low behind the center section of the bullbar at around the same height as the winch (but I mean, low) or remove the solenoid from the box and put up up in the engine bay next up in the firewall corner. It would mean insulating all ten contact points to prevent short outs but...might be a better option? Can anyone foresee any issues with this?
Biggsy
If you just bought the winch it should have the new style solenoid which only has 4 main thermals.
A good idea is to get isolation switch in the main power line. This way your winch will have no power until you turn the switch on.
Aslo if it is the new style waterproof solenoid and if it doesn't already, cut a section out of the control box to allow any moisture to escape. You find most control boxes are like this..
SMOKEYR50
Was your bullbar a winch comparable bullbar?
Yep, it's the ARB Sahara bar - winch bolted straight up. Only issue was the bottom bolts being a bit short to pass through the fair lead. Seems standard with these china winches.
SMOKEYR50
Hi biggsy, I attached a pic for you, what do you reckon? ImageUploadedByTapatalk1394844305.437858.jpg
