Reversing / Work lights
mills63
Ok here is the plan. I would like to use my work lights as my reversing lights. So from the front a 3 way switch
1) reversing
2) off
3)on all the time
Here's the tricky bit "well for me any way" I would also like to turn the work lights on from the rear of the Troll so I think I need a 2 way switch on there also.
I had a go at a diagram but cant work out how to get the 2 way switch to the rear in there.
Any ideas or have I got it completely wrong.
Thanks
Steve
**************** UPDATE **********************
Ok guy had a go at this and have managed to get the rear switch working but not quite right.
I have a led rocker switch with power in, power out, and earth.
Using the diagram below it is switch 2. but to get it to work I have relay wire going to power out and earth to earth. This is fine but it doesn't light up the LED. The switch is not running a accessory I am using it as a toggle switch I suppose. Is there any way to get this to light up or do I need a different rock switch type. and if so what.
Thanks
Steve
Mills
you could wire the front up as you have said then patch the rear switch from the reverse/worklight to an available positive. I don't see any problem doing it that way.
mills63
Mills
If I did that Rosco I could have an occasion were I have power from the front switch and power from the rear switch. If I have the front set to reversing the reversing light would come on as well as well I would have no way of turning it off from the front.
I was wondering if I may have to use a relay some how ?
Ok will have to keep on looking.
Thanks
Steve
Eightyeight
Just chuck a diode (jaycar) on the reverse light feed so when set to auto in the front, switching from the rear would also not trigger the factory reverse lamps.
I have front and rear switching for my reverse lamps, and yes using a relay is best so the power side is shorter runs. Thus your longer runs are only control wires ie: not flowing current to actually run the lights.
Checkout my ride in My Colorado build Thread!!!
93Patrol
I have mine wired so there's a switch in the front to turn on off for reversing and a switch in the back for work lights. They run separate relays and the switch in the back comes straight of my aux battery.
One thing to know is that you reverse lights aren't allowed to be higher than 1.2m from the ground and its a good idea to have your work lights switched off on The road otherwise you may get a fine or a defect notice. I turn mine on at night only
Eightyeight
Any reason you decided to run two relays and not just the one?
mills63
Hi Guys any chance of a diagram of some sort. Need to see were you are putting stuff in the circuits.
Thanks 93Patrol for the heads up on the revering lights and the height.
Thanks
Steve
93Patrol
No diagrams sorry. And the reason for the 2 was that's what I thought would work best. I am not really a thinking man or a planner I do what works haha.
I just found it easier this way for me honestly
GUnka
Steve,
In issue no.223 off 4wd Action mag there is a write up and wiring diagram for exactly what you want to do. Negates the need for an in cab switch, uses 2 relays so works off your reverse light and a separate switch at the back to switch it on/off if you want.
Can't post a pic up but would be happy to scan it and email it to you or lend you the mag if you like so you can go ya hardest....(then do mine for me....lol)
mills63
Thanks Gav will look for the mag I should have it here someone. Must of missed the article.
Thanks
Steve
mills63
Steve,
Hi Gav
Cant find my copy and the Blaw took his to work and has been unable to find his.
Could you take a copy of the artical or bring it with you to the xmas do.
Thanks
Steve
93Patrol
I put the reverse light switch behind the drivers reverse light and the aux switch up in where the Jack sits in the back
mills63
Ok guys got this from Gav and 4x4Action issue 223
Thanks
Steve
GUnka
Thanks
Steve
Hey Steve,
Recently installed one of these for my onboard compressor but I didn't bother wiring in the lighting because I couldn't be bothered and only use it during the day.
There are 2 lighting circuits in the switch and 2 LED's. One illuminates when switch is on which is on the side with the most pins. The other is on the other side to illuminate when you switch your lights on so will need to tap into the lighting circuit somewhere. Depending where you have mounted your switch will depend on where you get the lighting positive feed from.
I had same issue when installing my EGT and Boost gauges. The easiest and best one I found to use was the ash tray light in the centre console. Then loop the neg side over to the neg for the other "switch on" light neg so you only need to run one earth wire to body somewhere.
mills63
Gav not sure I have the same switch as you. Mine only have 3 prongs on the back power in, power out, earth.
Mine light up only when you turn the switch to the on position. They don't have the dash light option.
some thing like this. (see below)
The switch is at the back of the car so don't need to do the dash light thing not sure I would want all of the switches to light up if I had it at the front any way.
Going by this diagram I have power to prong 2 and earth to prong 4 and nothing on 3.
So I have connected 3 and 4 together to simulate a accessory but that made no diff.
Wondered if I needed to put some resistance over 3 and 4 to simulate a accessory rather than a piece of wire "no real resistance"
Thanks
Steve
GUnka
Ok, sorry mate. I have a similar switch only 3 pin for my light bar. Wired exactly the way you have done yours and my LED on the switch iluminates. My guess is dodgy/stuffed LED light in the switch, or bad earth. The earth pin on the switch is only for the light in the switch.
