Replacing factory toyota surf recovery hooks
Hey all recently aquired my surf, was my old mans... really happy with it, its had a lot of work done to it..
Quick question though, im trying to fit rated recovery hooks.. on mine there was a hook on the drivers side.. this was bent, i figured i could replace it with a rated one..
The old one came off by removing a couple of nuts, but the bolts seem like they are a part of the chassie... see pic
The hook that was removed:
The issue is i cant tell if they are high tensile or not... the spacing looks ok, so if i can get a rated hook to fit should i mount it in this location? As i cant see any where else it could be mounted and i have no way of removing those bolts..
secondly on the passenger side of the car it has the same bolts albeit shorter because there was no factory recovery point, just the tiedown point. So im a bit lost as to how to fit a recovery hook on this side..
See pic,
Any help would be awesome...
Cheers guys!
4runnerSteve
I have a 92 surf, on mine those are studs. Try spraying a tonne of WD40 around where it goes into the chassis and use mulitgrips or a spanner on the end if you can to flog them out, then replace with HT studs or bolts to be safe.
Frankensurf
Yep, same as above. '92 Surf. Threaded nuts are welded into the chassis rails and bolts go through the hooks from underneath.
Thats awesome so with a bit of persuasion i should be able to undo them with a pair of multigrips..
Should be fun, i needed to use a breaker bar to undo the nuts..
The shearing strength of those bolts should be ok for sand snatching, not to the axles or in wet sand (or sucking mud), but the avg kinda trouble you can get into on the QLD beaches.
My after market hook on the RHS chassis fitted in the same hole pattern as the small factory tie down (removed), new HT bolts and the aftermarket hook, all good.
I use this with the LHS factory hook, have used them both singular for light snatches, or I have a bridle if I feel the stresses might require it.
Maybe you can get a 3m bridle strap and use this with your setup, but again only for assistance type recoveries.
Otherwise, some engineered laser cut 10mm plates that bolt onto other more solid bolting points on the chassis might be better ?
You guys are legends...
used the smallest socket i had, and mild grunting.. too easy
I'de rather peice of mind with tensile bolts and rated hook..
2luxes
That hook that you have does have a rating. The owner's handbook will tell you it is for towing so there is no need for Toyota to write anything on it. The manufactures of aftermarket hooks designed to bolt straight on can't just sell you a plain unmarked hook. They have to have something on them so there will a figure of around 4500 kgs on the hook and the packet will be marked for towing only. There is little difference between the Toyota hook and anything that you will find in the 4x4 shops. At least you know who made the original hook but who knows where the aftermarket one came from.
Yours is not bent. You could not bend it through 90 degrees like that without breaking it.
4500 kgs is 9900 lbs which is very close to the popular 10000 lb winches that you see on many cars. The hooks will stand up to towing and winching but the forces generated in snatch straps can easily go well above that. That is why so many have broken resulting in many damaged cars, serious injuries and at least 13 deaths that I am aware of.
The other problem with any after market or home made things that use the original factory mounting points is they have to be attached to the two little factory fitted 10 mm captive nuts inside the chassis. They, and the thin chassis metal around them, have not been designed for snatching. I have read internet posts saying the bolts have been ripped out of the nuts. Two other posts have said the threads were stripped off high tensile bolts. High tensile is not another word for unbreakable.
It looks like those 10 mm factory fitted bolts have not changed over the years. I have three brand new Landcruiser ute and Troop Carrier hooks that were taken off new cars at work in the early 1980s so bull bars could be fitted. They are also attached with the same 10 mm bolts. They were towing hooks back then when there were no snatch straps and they are still towing hooks today.
If you must use a snatch strap then make it a last resort and do it gently. Unfortunately there is no clearly defined definition of what "gently" is. The worrying thing about it is if you are snatching another car, you have no idea of the condition of its attachment point. If it lets go because the bolts/nuts/hook have been overstressed through multiple snatches, the chassis has started to develop stress cracks or the bolts/nuts inside the chassis are corroded then the hook will fly into the back of your car at better than 300 kph.
Hey guys... well I installed one recovery point see pic:
The other one is giving me grief, I have managed to remove one lug/bolt what ever you want to call it, But the other one was turning then my 8mm socket started to slip as the bolt jammed, Ive spent the best part of 2 hours and about 60 bucks on tools to remove it but to no avail. Any advice? My next step is to take it to my local mechanic as they will have other means.. (At least I hope)
Any advice would be great...
If you have a mate with oxy gear, you could try heat.
Keep it on the outer part of the problem mostly, but the heat should help break bond.
I have had luck with the cold spray too, applied to the bolt only if you can aim that good.
The temp discrepency help break bonds of stuck / rusted threads.
Thanks mate.. Nah I dont.. But its all good, ill Take it down to my local mechanic during the week.. It bloody shits me to tears though.. Last bolt.. Seriously... :mad::mad::mad: Its alwase the last bloody bolt....
80lover96gxl
The captive nut sounds like its now un captive and is turning with the bolt.
If you have a mate with a welder you maybe able to get a tack on that nut to the chassis to stop it spinning, then weld a nut or bolt to the stripped bolt to get a spanner on it again.
Iv had to do this to my old cruiser when the captive nut broke its weld when taking a bullbar off once with good success.
Thanks mate, its still captive.. and its holding my bolt to ransome.. ... nothings turning.. the frustrating thing is i dont think there is much of the bolt in the nut.. its almost out.. but now it wont budge...
Edit: welding a nut on there is damn genius...
I thought mine was bloody tough..
80lover96gxl's suggestion got me thinking..
I cant weld but what about that liquid weld stuff.. jb weld? Has anyone used it?
http://www.jbweld.com/
Ive got high tensile nuts that i didnt need from the other recovery point.. im tempted to try it, but if i fail i dont want to make it any harder for the mechanics to remove the bolt..
80lover96gxl
Never tried that stuff but it sounds impressive.
If you do manage to get those bolts out, the new ones you use add some never sieze to the threads, should be able to get it from most auto stores, will prevent the problem your having should you need to remove those bolts in future.
If you havent already, try spraying some penetrating lubricant like WD40 to the stuck bolts and wind them back in and out a few times, this should help free them up.
I'm wondering if one was a bolt and captive nut (the one you got out) and the other is a fixed stud in the chassis ??
Could be, can you see a captive nut in the gap (if possible) ?
Anyway, I suppose it has to go either way, could be a nut might need to be welded inside by some clever mech.
4runnerSteve
No glue i know of bonds nuts strongly enough to unstick a stuck stud. im guessing you have already doused it with penetrating oil/WD40 or something similar.
Since you can't reuse the stud anyway, have you tried cutting and drilling it away? you need to be very careful not to damage the thread inside.
