Removing wheel studs HJ60
darthvincor
Hi everyone,
I recently wanted to add a mud flap, which I removed to do some rust prevention, and took the wheel off to give myself some room to work, and when putting the wheel back on, a stud broke off.
So I got a set of new studs, removed the wheel, the brake rotor, the broken stud, but now I'm stuck because I can't get the studs on or off the hub, as there doesn't appear to be enough space behind the hub to remove the studs.
I can get them loose, just not out.
Here's a photo:
As you can see, the 11 o'clock stud is loose, and the broken 9 o'clock stud is out.
Am I missing the one little spot that gives it room for stud removal, or will more stuff need to come off?
Thanks
chris_stoffa
try dismantling your brake components, if that doesn't give you the room you need , you will have to dismantle the axle from the backing plate.
you may be able loosen the backing plate off enough to give yourself enough room but i doubt it .
Just remove the axle , replace studs and while your in there consider new seals at least and maybe wheel bearings
croozza
1. try turning the hub till you find you have room, then put the new stud in, it will tighten up when you put the wheel back on and do up all the wheel studs, check the wheel studs after a quick trip around the block.
or
2. You can remove the hub, it is a full floating hub so it is not hard to do, undo (not all the way) the 6 10mm nuts, nock out the cleets (by hitting the hub above each ot the nuts) when the have all popped, you can then remove the nuts,washers and cleets, remove the axel (be carefull of the axel seal), then undo the wheel bearing by undoing the outer lock nut, then the locking ring and then finally the inner locking nut, then the hub will then come off. Assembly is the reverse of the above procedure. Just need to straighten out the locking ring, and then bend it back so that it will lock the nuts.
darthvincor
I looked at the brake components, but the only bolts that can be removed are behind the hub. And I'll look at the seal, see what state it is in.
or
I tried rotating the hub, but there was never enough space, no matter where I tried.
I'm now trying to remove the cone washers (cleets). They are on pretty tight.
