Unless some of the individual strands have broken IMO your cable is still perfectly fine to use. Photos would help tho.
All it takes to put a kink in a cable is an ever so slightly slack winding under the top layer of cable and the top layer will 'pinch' the cable below it putting a kink in it.
If the kink is really minor, simply unspooling it then respooling the whole cable nice and tight it will often straighten itself out.
If it is a little worse, try some multigrips, a vice, a hammer and see how you go... AGAIN provided none of the individual strands have broken the cable should be completely fine.
But even with a couple of broken individual strands, id trust steel over rope anyday unless you go playing in the mud every weekend or have a comp truck.
None of the cheaper ropes - Dyneema etc. are truly UV stabilized and sun exposure will deteriorate them. Sand, mud, wet, heat... it all effects rope, cable not so much. Fancy unspooling the rope every time you take the vehicle bush / get the rope wet / dirty, to wash and dry it... Again, unless you expect to use it all the time no thanks.
Travis.
