patrol dude
Hi Guys, i have read a bit about Red Line - Water Wetter it appears to be OK. Would love some real world feed back on it. I drive a 2000 4.2TD Patrol and am looking at dropping the temp just a little bit, thought this might help. Any feed back would be greatly appriciated. Cheers
Red Line Synthetic Oil - WaterWetter® Coolant Additives - WaterWetter®
WaterWetter®
Unique agent for cooling systems that doubles the wetting ability of water
Rust and corrosion protection allows for use of straight water in racing or reduced antifreeze levels in warm climates
Improves heat transfer and reduces cylinder head temperature
May allow more spark advance for increase power and efficiency
Use one bottle for most passenger cars and light trucks, treats 3 to 5 gallons or 13.2 to 15.9 liters. Vehicles with larger cooling systems should use two bottles. Small cooling systems should use 1oz (3 to 4 capfuls) per quart
Compatible with new or used antifreeze (including DEX-COOLTM and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems
Satisfies ASTM D2570 and ASTM D1384 corrosion tests for glycol-based antifreezes
ABOUT RED LINE WATERWETTER® COOLANT ADDITIVES
Reduces or eliminates bubbles or vapor barrier that form on hot metal surfaces to reduce coolant temperatures by up to 20°
Superior heat transfer properties compared to glycol-based antifreeze
Compatible with new or used antifreeze (including DEX-COOL and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems
Designed for use with all modern aluminum, cast iron, copper, brass and bronze cooling systems
Cleans and lubricates water pump seals
Reduces cavitation and complexes with hard water to reduce scaling
Does not lower cooling system below the thermostatically-controlled temperature
WaterWetter®
