Red arc brake controller remote unit
Boehamian
Hi guys,
ARB just fitted an electric brake controller in my new RG Colorado but they put it in a stupid spot. Every time I lift my foot off the clutch my boot hits it. Want to move it but am not sure where. Anyone installed one of these and know where to put it?
Was looking at cable tying to the clutch pedal mount and industrial velcroing it. Anyone else have any other suggestions. Am a little limited because of cable length, but pretty much anywhere behind the dash on the drivers side except to the right of the steering wheel.
rogerazz
G'day. I have an interchangable Tekonsha brake controller for my car and my Troopy.
Not sure if your red arc has a manual brake applicator like mine which allows me to activate brakes on my van by manually pulling a lever across the unit. Handy in an emergency if you lose control of your van or trailer and you need to apply the brakes without using your vehicle brakes.
What i am getting at is, the car cradle is under the dash near my left knee and the Troopy cradle is under the dash right of my right knee.
Because I am right handed it is easy for me to reach under the dash of my Troopy and manually activate with my right hand. The one in the car is a pain and luckily the car is auto or I would be hitting it with my left knee all the time.
Make sure your cradle or unit is installed well to the right of you, as close to the door as possible so you don't hit it with your right knee when you brake and can still reach it with a finger touch.
If wiring is to short i would look at extending to fit in correct position.
Please ignore this post if it does not apply to Red Arc. at all.
Cheers.
chris_stoffa
Don't alter a thing - Once you work out where you want to put it take it back and tell them where to fit it. (physically that is , not literally . :D)
They have fitted it in a location that interferes with the safe operation of your vehicle, so suggest that they may want to move it rather than have a damages claim should it cause or contribute to an accident.
Their head office and Legal Beagles will understand if the local dealer doesn't. ;)
Buxter
Boehamian
For my 2 cents worth !
In viewing the RG Colorado dashboard, Can you put it on the dashboard above the volume button, on the "flat section"
check out the foto I found on the net, put it just in front of the gear lever
I fitted one to the "mighty Poootrol"
Am not sure about "cable length" ?
The remote unit is mounted (cable tied, also) behind the dash on a big wiring loom.
The "Controller button and LED" are located on the left side of the center Dash, well within easy reach of the driver.
No more knee knocking for me !
Buxter
garrys
mine is on the left leg side so it doesn't really interfere with the driving which uses the right leg. it was pretty annoying at first but guess I got over it now.
Billy C
G'day Boehamian, In my RG the brake controller is mounted on the right hand side just to the left of the headlight on/off dial. Could be worth a bit of extra cable to locate it where you want it. Thankfully I haven't had to use it yet and it certainly doesn't get in the way. My knee thanks it for this!
