Reasr Camera Wiring
Bookleaf
Am about to take ownership of a Mux LS-M.
Among other tings, I would like a rear view camera to aid connecting up the camper.
Will possibly achieve this via a GPS, multi function, third party 2 Din head unit.
Re the camera, does any one know if the wiring for the rear camera is already there as part of the standard loom? Or is it a special loom for the LS-T, or run separately on the LS-T?
Not sure about the MUX mate, I would be surprised if there was a suitable power wire in situ, though many tap into the reverse light to give power at that time of operating reverse gear.
Your camera is bluetooth I imagine ?
I was advised off these and that video cabling would give better vision, reliability etc, so ran all power / visual cabling from the front, installed a nice big length of corrugated split tubing for wiring right through, and laid all the extra HD wiring through there to take to the back cabin and tub while in there.
Bookleaf
Thanks Les
As I have not purchased the unit yet, photos show it as a cable camera. I was wondering if the cable was already there in the MUX though, then I would not have to run any cable to the back light (and get revers light power).
As a matter of interest, what was the rout that you used to run your corrugated tube?
Like the idea of using the tube and thus allowing for trailer power etc, as well within it.
I wired the corrugated split tubing high up against the chassis, used large cable ties.
Think the one I used was a 19mm conduit, which can hold a heap of cables, have a power block in the back of the cabin, and another in the tub.
With the wagon, you might have a large-ish plug under the back of the quarter panels that you could use to split off some wiring to go insude, and other wiring to the back for trailer power (Anderson plug type arrangement ?).
Bookleaf
Thanks Les
