Rear window won't work! 1991 4Runner
Willow_23
Hi all,
Having an issue with my rear window on my 4Runner. It won't go up or down on the switch but it'll go down with the key (but not up). I've checked th wiper position and made sure it's in place. I've checked the fuse in the kick panel as well. Is there anything I'm missing?
Thanks guys
typhoeus
have you tried applying 12v to the motor directly to make sure the motor works properly ( up and down)? if so then it has to be the switch or wiring, I would then start with the switches. a workshop manual would be really helpfull here.
Paddler Ed
Does it work with the key from outside? (OK... re-read OP and that's sort of OK)
Have you knocked any of the window lock switches? Mine has one on the drivers door rest and one in the centre console, near the updown switch? (Might still apply)
Does it flick the voltmeter on the dash when you try putting the window up? If so then the switch is sending power to get it up, but not down... give the switch a squirt with some contact cleaner and rock it back and forwards a few times and see if that helps. (Might still apply)
Mine recently stopped working, and all it needed was a bit more of a push on the down button and it was all good.
What it sounds like is that the motor is spinning, but not engaging. Have you got the tailgate shut properly? There's a switch IIRC that tells the motor that the tailgate is shut (and locked; try manually pushing the lock tab down)
FSM available here...
