Rear Mud Flaps
Davidman
Just wondering if anyone has done any mods to, or replaced their rear mud flaps. The moulded plastic (stock) ones on the Pajero are taking a bit of a beating and the screws that go into the expandable plastic retainers aren't what they used to be.
Any pics would be good.
Thanks
frosty
mmmm. My mudflaps fell of with my rear bumper!! Sorry! Replaced bumper with steel and tapped into it. Bolted flaps on.
Most states are different but in QLD, the bottom of the flap must be 17 deg. below the axle center.
I'll bet tassies different.
knot_gillty
Wrong Beaconsfield mate...
I wasn't aware of any laws stating how low or high or long etc mud flaps had to be. Maybe something worth looking into. I've got some mud flaps here if you like David. They aren't the moulded ones for a Pajero, they are the thick rubber ones that you bolt on. They also have Johnno's Camper Trailers printed on them....:eek::rolleyes::rolleyes:
A bit pricey though, we paid $60 a pair so it's all i would ask from a fellow 4x4 earth member.:D:rolleyes:
PLUG!!!!
frosty
PLUG!!!!
Is there 2 Beaconsfields?? Oh well. Just check with ya DOT. I've been pinged for flaps on my trucks a couple of times over the years. So long as you've something, I don't think they care to much on cars. When I built the new bar for thr Patrol, I got slack and did'nt put the flaps straight on. YEP! Sure enough, they got me. Got a warning after explaining circumstances.
centaur
My HJ 60 series was registered less than 2 years ago, and went through a full roadworthy. My mud flaps had to level or lower than the axle line. I cut down some truck ones to get past. I have since replaced with moulded Toyota items, but will need to redo once the lift kit goes on.
So if they clear the axle line, you are right to go. Whether they are standard to home made, they dont care as long as they are securely fastened to body.
Hope this helps.
