Rear auto diff lokka?
oobi
I've already got one in the front and it's awsome off road!
I was looking into putting one in the rear of my IFS lux but I'm worried about how it will act on the black top I know it only locks when under load which is why I'm seeing how ppl find it for drivability on road as off road would be awsome and an air locker is out of my price range.
Is it tail happy in the wet? Etc
Thanks 4 your help :)
croozza
If you put it in the rear, it will be very tail happy in the wet, The way the auto lockers work is they are always locked, and only unlock when you have no power going to it, your driving style will have to change, (coast around a corner more).
yobboford
once above car park speeds you can hardly even notice its there, yes it does lock and unlock all the time but its not very noticeable once you are at speed.
As for it being tail happy in the wet, this is only true if you have bad tyres and drive aggressively with too much power, In a heavy 4wd it is not as much an issue as say locking the diff in a cortina (lots of tail happy fun in the wet) but you do have to drive accordingly, remember a locker doesn't make you lose it on a corner, your driving makes you lose it.
Now for the down side, at car park speeds, pulling u-turns and three point turns they SUCK, they have a tendency to "pig root" with the back lash in them driving you crazy. I am pulling the one out of the back of my 80 due to this, I am doing more touring and camping now and I really notice it with the camper trailer on trying to move it around so out it is coming.
For the last year I have had them front and rear, (keeping the front), and they have been awesome off road, but I wasn't driving mine everyday, just a weekend warrior. So my advice is if its an everyday car don't do it, if it isn't then its one of the best bang for buck mods you can do.
oobi
Thanks for your input I hope to see some more opinions on a rear auto lokka in an everyday car. Because the pros off road are outweighing the cons on road but then again I haven't experienced the rear on road....
Not sold either way yet
OGJON
rear lsd an option?
a well shimmed lsd can be almost as good as an auto lokka but way more low speed black top friendly.
oobi
It would be an option if I still had my gq patrol... The LSD in the Nissan shit over the Toyota LSD.
I was looking in to the Detroit true track does anyone know if there worth it????
Alien d2
Ive just fitted a Truetrac(by detroit) to the rear of my toy.
It was recomended as gentler on the drive train than a locker.
The Truetrac is a mechanical LSD so acts as a normal diff when in on road use.
It "locks" under load and drops out once the power is removed.
It works on a sun gear type of arrangement so suited me as I want to get away from spider gears.
So far on dry tar no differance.
On high speed dirt it can under steer under heavy load as pusing from the back, fine on normal throtle input.
Havn't played in "extreme" stuff yet as no time to orginize a travel buddy at short notice.
Jack48 has one in the front, not sure what the back is but it is mechanical, a search should find his fitting thread and more details.
jack48
Have auto front and rear in Tonkadore, just adjust your driving style, easy to get the hang of, if you are a driver :p
Give it heaps through a corner at the start and then back off, you can feel the understeer disappear ;):)
It is the same on tracks, unlike air lockers, when you loose steering capacity :eek::eek:
Auto lockers for me anytime over air :D:D
Alien d2
How much is the true track and where is the best place to buy it from?
We paid $900 for it from our local Opposite Lock outlet.
Plus $40 for carier bearings from the local bearing shop.
Not a lot of $$$ saving found on evil-bay and peace of mind for any warrenty if needed.
Also quoted @ $250 to fitt it to my diff centre if I removed it.
I did the whole lot at home as I had access to a press for the 2 bearings.
Ball park figures....
Detroit locker.....$1100
E'locker.............$1500
supraturb
Good info folks, I have a D-max which has LSD in rear, it pretty much gets me to more places, but not all... D-max is now making way for PX Ranger which has a locked rear, I have read articles on the Lokka and feel it is a better arranement particularly if I can put one in the front also... comments
HGturbo
I run auto lockers front & back (have done for years now) and love'em.
I tow a trailer during work hrs and the auto locker is fantastic to tow with, if you set them up right at the start they are smooth as. I can do tight turns, U turns and round abouts with ease (I very rarley get the bangs or pig rooting).
I have found if it is not shimmed properly or the hemisphere pin is worn to much it will rachet & bang alot and will be twitchy on the road.
It is a different feel when driving an auto locked car to an open diffed car but I think it a more responsive feel.
I tend to change the pin in the hemisphere & use new oil washers when setting up an auto diff (I have set up a fair few over the years) and the No.1 reason for an auto locker not being smooth on the road is the pins are put in the wrong way..
I have played with air lockers in the past but prefer the auto lockers.
They can handle big HP with ease and can launch the car straight & true every time.
I have broken a locker (Richmond) with in a year of install, all 4 pins snapped & then a pin smashed the face of the locker.
The unit was replaced free, no questions asked and it was expressed to my door the following day.
supraturb
lokka
Thanks HG
All makes perfect sence to me! Electric locked diff installed in rear will be removed and replaced by lokka centre plus one for front - see you at the top of the mountain!
Great info much appreciated
Hiya HG
Yeah ive read a lot about them,so you need them installed by someone who does them regularly...If you get the Backlash wrong youll get Clunking etc etc...
Good feedback about the Supplier...
