Rav 4 with no low range at Stockton
ferozious
Hi,
My friend has bought himself a 2005 Rav 4, which has constant 4wd system and a VCU to lock the centre differential, but it doesn't have low range. Its got something like a 2.5L engine in it.
Would this be able to cope for a day of beach driving out at Stockton without low range gearing??
Has anyone seen any of the other soft-roaders which don't have low range out on the beach?
I've only ever driven my Feroza on the beach once, so wanted head out with this friend out next weekend with his Rav 4, but just checking to make sure if it would cope?
logitech
Used to a rav4 and beach driving was fine. it will drag along some parts due to lower clearance but due to its lightness, floats over alot of boggy sand.
frosty
Do you see Pwados on the beach????????
That should answer your question!!
And if see a big dune,,, give it HEAPS!!!!
goldrush
Treat it like a Prado and avoid the soft sand. Take a capable recovery vehicle with you, just in case.
croozza
You said that wrong goldrush, it shoud read, Treat it like a Prado and you will be dragging the Patrols out all day.:D:D:D:D:D:D
GPS Guru
We just got rid of the missus's (2002) Rav. Whenever it rained, the speedo would stop. It was put down to a leaking sunroof as apparently there is some drain in there that supposedly goes via the kick panel or something. The sunroof had a slight leak. Toyota tried twice to fix it and ARB had a go too. Toyota's response was to buy another sunroof. $1300.00. No thankyou....And I told her not to buy a Toyota becaue of previous issues I have had with them. So we picked up a Mitsubishi Challenger on Saturday. Very impressed so far. It compliments the Nissan nicely.
croozza
Well it is not the sunroof leaking then, the seal around the glass section of the roof is not waterproof, the problem was in the drainage in the kick panel. Possably a grommet had fallen out.
bmurray2250
Hi,
Shouldn't be an issue, you may see Kluger's on the beach too. They don't have low range either. Seen many Rav$'s on Fraser and no problems unless you follow in the track that are too deep. Lower the tyre pressures to 20lb and should even go up the top of the dunes where the anti-tank boundary are
rickgq
Yeah it will be fine, i took my mrs 2004 model to stockton, drop the tyres to 12psi and it drove around like a taxi all day, it actually drove so good it really impressed me.
Morayman
I have a Rav4 (2006) no low range - and have taken it all over Stockton - from Anna Bay past the Sygna wreck. The sand is very soft near the wreck, but I had no problems at all.
I've also done some of the larger dunes. I dont know about the pre-2006 Ravs, but my 4x4 cuts out over 40km so I ended up traversing many of the dune in front-wheel drive. The only prob I had was that stupid plastic cover under the engine that seems to get a hiding.
As someone mentioned before - put your tyres down to 12psi.
[YOUTUBE]u72F692k8uM[/YOUTUBE]
aarond
took my parents to Stockton beach yesterday in a 2010 Nissan XTrail auto with no low range with 18inch low profile road tires.. let them down to 14psi and didn't bag out much but didn't have to pull them out once.
there was a few big dunes they couldn't get up, but mind you i struggled up them too and had to have a few gos.
down near the wreck it got a bit harder for them but they never got stuck.
i actually tried to get the purposely bogged once, to show him how to dig out in front of the wheels and then if that doesn't work, id snatch him out. so i told him to put in in 2wd and he dug the front wheels in then back in 4wd. then he bogged it down til maybe 5-10cm from the body. they he went backwards and forwards a little and turned the wheels left and right, next thing i know he was out!
