The 80 should already have them on it, there should be 2 on the front and 2 on the rear, they came like that from the factory, if they were removed you might need to find out why, have a look under the vehicle at where the points are located, and see if there is any damage. They bolt up under the chassis and should be hoop sytle points.
They're tie down points only. Toyota will not tell they are for recovery. They are not rated.
Are they rated?? They look like a bit of bent 10mm rod to me.
And the aftermarket ones look like a plate with a hole drilled in it to me.
Odd looking hook then. Isn't this thread about recovery hooks????
recovery hooks, recovery loops, recovery points, all in the same kettle of fish. It is just a term to decribe the same thing.
Most Nissans I've seen only have recovery points for Toyotas on the back, I'm not sure if these need to be rated or not....
