Ranger Danger
a1bert
Thought i would post to get a few ideas
Twice in the last two days i have had a frightening experience with a 1917 Ford Ranger, 130,000ks
The first situation was at a roundabout on a major road doing a right hand turn, having nearly completed the turn the steering wheel ripped out of my hands and did a violent turn to the left across the left lane and nearly into the Armco. If a car was there it would have been cactus
Secondly, yesterday when doing a right U turn on a major highway, once again when the turn was nearly complete , the steering wheel again violently ripped out of my hands and did a left turn before i could rest it under control
Both experiences lasted for approx 3 seconds
This vehicle is fitted with adapted cruise control, but in both cases would have been turned off
When the problem is Googled i cannot find any like incidents!
Will give the radar box a scrub with a wet brush to ensure no foreign matter on it
Didn’t you know Henry Ford had them on his drawing board back then but figured the model T with it's simplicity would have less issues, be more reliable and plastic wasn't as radially available either.
Oh did I say that out loud haha.
Sounds like a front camera/pre collision assist malfunction. Check your battery health and clean the windscreen in front of the cameras would be my first thought.
a1bert
Thanks guys, on the second occasion managed to glimpse the warning sign, down hill assist not engaged! (wasn't activated)
Have cleaned the radar box, disengaged lane assist, note lane assist is supposed to turn off under 60k's an hour
My money is on the lane assist is not deactivating under 60kph!
a1bert
To finalize this thread, the culprit, a scan gauge!
Permanently installed for 7 years, the facia recently went blank.
Some errors started appearing on car screen, removed scangauge and all seems ok
At $445 for a new one, i don't think i will be bothering, although it was good for giving accurate tyre pressures
To have one permanently installed is good if you want to constantly monitor live values of sensors and temperatures of everything but who could be bothered
My scan tool lives in it box under the seat and only gets used when there’s a fault, touch wood it’s never been pulled out from under the seat but well worth having it there
CTL
I have the CarScanner app and a quality OBD dongle. Works on Apple CarPlay. Just flick the screen when I want to see trans temps etc. No extra screens or clutter.
Interesting, I am still using the Scanguage 2.
Is it the Elm OBD2 that you have and it works on CarPlay?
CTL
@Albynsw I would have to check. I choose the dongle from a list recommended by CarScanner. Have read of others having issues due to incompatibility.
Using CarScanner on your phone (which I did and can still do) allows you to customise the screen with different gauges of your choice, colours, alarms, etc. Using it on CarPlay, it only shows as text. Whilst not as fancy, it is functional and all I need. I believe the developer is working on a better CarPlay interface.
I use the same, carscanner app and a vlinker dongle https://www.carscanner.info/choosing-obdii-adapter/
Saved me a new engine as the alarm went off on the coolant at 115 when the day gauge had only just started to creep up (I had holed the radiator and lost all coolant)
Wouldn’t the low coolant alarm built into the car do exactly the same, as soon as the coolant system in mine gets to about 1 litre down the car tells you with dash warnings
smitty_r51
Not on the pathfinder it didn't, not sure it had a low coolant alarm on it...
first we knew was the scan app set of an alarm, then the aircon blew warm, then we lost power... but i was already pulling over and stopping the engine.
still running the same system in the Ranger now (touch wood haven't needed it yet)
Fingers in Aus
I have an Engineguard on my 15 PXII XLT.
It gives a visual and audible alarm once the sensor picks up an over temp situation.
Haven't had a failure causing it to activate, but I have been using it to monitor temps, especially while towing.
They have some good videos on their website
TowingMate
The issue a1bert ran into usually happens with older, dedicated hardware (like an aging ScanGauge) that constantly queries multiple ECUs on rigid intervals. If its internal logic fails, it can flood the vehicle's data network with noisy requests, messing with critical signals.
In contrast, modern setups—like a low-energy Bluetooth (BLE) dongle running an app like CarScanner on your phone—work differently. The phone does the heavy lifting, and the dongle just streams data. If anything glitches, the phone simply drops connection rather than flooding the bus.
For anyone towing heavy loads, smitty_r51 is spot on. Standard dashboard temp gauges are heavily dampened; by the time the needle starts creeping up, you are usually already in trouble. Monitoring live data (like transmission or cylinder head temps) gives you a vital 2 or 3-minute warning before any dash alarm sounds. For serious towing, having that live visibility is a game-changer!
