redandy3575
Range Rover HSE 4.6L, 1996
Good Points
Very comfortable and smooth on the road, Very capable & stable off road,fantastic axle articulation on uneven terrain, adjustable ride height via Air Suspension makes this vehicle acustomed to just about any road condition, Powerful 4.6L V8 has plenty of torque to tackle those steep inclines and off-course that great V8 rumble, plenty of room in front, rear seats & spacious load area in the back, Great approach, ramp over & departure angles. Features: ABS, Traction Control (Rear wheels only), Permanent 4WD, High & low range via H-pattern Auto.
Bad Points
if an Air suspension fault occurs the system goes into limp home mode lowering it to the bumbstops. Unless you have a repair kit and a EAS kicker device to reset the ECU, then your off road adventure is over for the day and a trip to the dealer or specialist to diagnose and reset the fault along with a big cheque. The ride is a little wishy washy around corners giving the impression that it might tip over due to the softer suspension but once you get used to it your confidence returns. Little thirsty on the fuel averaging 15.6L/100km but a lighter right foot will return you back to around 13L/100km. Also get used to oil leaks as the British haven't lost their sense of humour and the series 2 rangie can shed a drop or two (not as bad as the series 1 though). I don't think you can get lockers for these (genuine & aftermarket) as it conflicts with the Traction Control and Land Rover don't recommend it. Cosmetically: just watch those plastic door handles as rough treatment can easily break the trigger latch inside the door (easily repaired though).
What mods have you done?
None so far. Stock standard.
All terrain tyres
Hard Range bull bar
Warn Winch
tint windows
set of Lightforce spotlights
Diff housing guards
spare wheel brace at rear
LPG conversion
Why did you buy this vehicle?
I was originally looking towards purchasing a used 80 series Toyota Landcruiser but with a $15,000 limit, finding one in good condition with low milage under 200,000km proofed near impossible and if one came along, it would have been sold before you'd have the chance to enquire about it. Nissan Patrols were a little cheaper however not many in good shape at that price.
I have always had a bit of a soft spot for Range Rovers since i was in nappies and watching some of those 4x4 maniacks compete in the international Camel Trophy race, i have always had the Rangies in the back of my mind. But more seriously, there are plenty of the series 2 Range Rovers on the used market today, and most of which have never been off-road. Also the mass depreciation on the price has brought them well within the affortability level. Mine was $13,000 with only 135,000 km, 12 months reg, mechanically A1 and as long as your not the silly goose that bought it new ($114,000 at the time), it's not a bad buy. But most off all, i like to be a bit different, unique, not always jump on the band wagon and hopefully proof some of the critics wrong as Range Rovers are a very under estimated vehicle to most (including the people that own them).
How often do you go offroad?
currently once a month
Series 3 Range Rover
Good Points
Bad Points
All terrain tyres
Hard Range bull bar
Warn Winch
tint windows
Diff housing guards
LPG conversion
