PX Ranger diff drop install
mac_man_luke
Yesterday i set about installing a monster rides diff drop in my PX ranger
to improve CV angles and life.
After jacking the front end up i had a feel of the wheels to see if i could feel any binding at full droop with the diff at stock height but there was none but i don't think it there was much room left before they would have and improved angles will still increase the life of the CVs.
CV angle before diff drop
Step 1: This bracket needs to go, out with the grinder :eek:
Bracket cut off
Bracket
Left over bracket / welds ground down
Painted and new bracket bolted in using existing cross member bolts.
Diff supported
Step 2: Front mount standard
Standard front mounting vs drop mounting bracket
Tailshaft bolts loosed, 20mm spacer installed (no pictures) with new bolts.
Step 3: Rear top diff mount undone and alloy block installed inbetween (no pics)
CV angles after install, not quite factory but much better than before.
Did it all on jack stands and lying on my back which was not real fun.
Would have been much easier on a hoist, especially the grinding.
Part 2: Bash plate modification
Buds customs bash plate
Trusty plasma cutter made light work of the 4mm plate
Test fit
Start of the cardboard template
Complete rough template
Progress so far
New vs old, bit bigger but smoother ramp on the front shouldn't cause too many issues.
Should have the bash plate finished sometime this week then hopefully test it out next weekend :)
80lover96gxl
Nice work luke, looks like you've been pretty busy mate.
Bash plate mk11 should look good once done.
Looking forward to checking it out.
mac_man_luke
yea certainly have been, too much for one weekend haha.
I used 6mm plate on the bash plate modifications because its all i had so should be pretty beefy haha.
Nice job Luke, will give a lot of peace of mind for future longevity of the Ranger off road.
GUnka
Top work mate. Looks like you lost little if any clearance through the centre too. Should definitely give you peace of mind when hitting the tracks now. :D
Just a thought with your diff guard extension might be to put a reasonable size hole or slot in that small section off flat bar as a drain as looks like it may be a low point and will stop any water, mud and crud accumulating and potentially working it's way into the mount bush and pin. Can also blast out the area with a pressure cleaner or hose and save having to remove the guard.
mac_man_luke
Haha great minds think alike ;) previous part was quite rusty on the inside from pooling water / mud so plan was to put a hole in this one :)
Last night / tonight i finished welding it up
Unfortunately tonight i ran out of MIG wire so had to resort to stick welding
the rest which didn't look quite as nice but most ended up ground down any way.
Got a first coat of paint on it too:
GUnka
Good stuff Luke, looks the goods and the extra thickness of 6mm will certainly mean there's plenty of strength there. Nothing wrong with hitting it with the sticks instead of mig either as we always opted for them over mig when strength is required. Means a little more work when comes to finishing but nothing a flap disc couldn't cure.
Did you consider getting it hot dip galved? I used a place a little while ago just of grand Junction Rd up around Wingfield for a heap of brackets I made up for the rear veranda I built and they were pretty reasonable cost wise. With all the returns etc in your bash plate you wouldn't have to worry about any warping either.
GUnka
Haha yea, i reckon ill aim for the Vic meet all going well.
Same here. Waiting to find out dates so see if works for me yet though. If not may have to make a plan to get there sooner rather than late. Pick up my car Friday...AGAIN... after diff lock debacle.
mac_man_luke
Thought about it, will see how the paint goes.
It was zinc coated which was doing ok other than where the mud/water collected
Front bash plate is silver zinc which looks quite nice and has held up ok.
GUnka
The brackets I had done were more a shiny silver zinc galv finish rather than your typical matt thick hot galv look. From memory this is the place I used and where we used to take our work stuff.
Hi-Galv, Wingfield - Cylex® profile
Benvette
Awesome work. I want to do the diff drop next so I can maybe space the existing lift kit then so I can get 35s under the beast. I might need to look at diff ratios then. Hmmmm.
Thanks for the inspiration.
mac_man_luke
Yea its a worth while addition. 35s could be risky, the CVs are not real tough
No other ratios available as far as i know
