PVC water pipe tank
extrajoss
Hi,
I have been researching the PVC water pipe tank, which i hope to place along side my roof rack on my Mazda Bravo.
I have researched all about the right primers and solutions and pipe to use and how to keep it clean etc. though just wondering if anyone had any ideas on how to make the tap for one end? AND the best way to fill it or design the filling end?
has anyone done this or have a good idea in mind?
ta
BTFIVO
You'll be surprised of what you can find at Bunnings in the plumbing/irregation section. I probably wouldn't be using any glues, but rather use teflon thread-tape to seal threads. Wash the pipe out with dish-detergent & rinse thoroughly before assemply. You'll need a hole saw & a thread-tap to match the threads of any "taps or bungs" you install. I'd mount the pipe at a very slight angle to get the water to the draining end, where you'll fit the tap and fit a threaded bung at the other end where you'll fill. This also allows air to properly escape while you fill.
Another way is instead of fitting a filler cap, install a bleeder valve and fill via the drain tap (providing you've installed a common gardenhose snap fitting) but make sure you fill using a food-grade hose and not typical garden hose. I've been eyeing off one of these for a while now, and is how I'd go about it.
mac_man_luke
Not sure id want a water tank on the roof.
Decent amount of weight, not great to be hung over one side and can be quite dynamic if not full (eg water moving back and forward with braking/acceleration)
No room under the car or in the tray?
From my reply to your post in the intro section . . .
What have you found about about water from storage in normal PVC pipe being not suitable for drinking ?
I've read numerous posts in the past on various forums about PVC leaching chemicals, but you can perhaps get some safer food safe material ?
Perhaps cleaning out after each trip, refilling only on leaving for trip and using water over a few days might negate this problem, not sure.
You might just want some water for hand washing, dish cleaning etc, where this wouldn't matter, that would be quite handy too.
I like the idea of going under tray, rather than up high.
Many roof racks do have a fairly low max load, and good to keep weight lower in a vehicle so not top heavy (and water is heavy).
If under tray, another good thing is you can put several U turns in the pipe, which baffles movement in the pipes when travelling, and easy to put a tap out the back somewhere, keeping in mind departure points / low spots that could damage piping / tap.
I'm just looking at a Dolium tank Water (Poly) - Dolium Pty Ltd (they also have bladders via the website menu) that will go in the tray somewhere, but found the one I really like (goes up the front of the tub, takes up only 80mm) it's just too high to enable window to open between cab and canopy. Poly Tank 42Lt Vert Mnt - Dolium Pty Ltd
Dolium have an optional pump, food safe hose, and tap kit, and their tanks / gear are very well priced.
Opposite Lock are agents in SA, and they bring in without ship charges, just pricing as per Dolium site.
FODFA
I have a 20 lt PVC tank on my roof rack, we only use it for showers so not concerned about leaching or anything like that.
As far as filling goes, I used 100mm swv pipe and put a T piece in with a screw on top, easy to fill even if using a bucket from a creek.
Cheers Andrew
mac_man_luke
Brown davis are just about to release a set of tanks called tray tanks in all different configurations. One i like the look of is 65L of fuel + 40L of water. 230 deep but not as high as the dolium tanks.
That sounds alright . . . but expect they will have BD pricing : /
Will email them and ask about what will be available.
A combo one would be good, except wth the Dolium I was going to piggy back 2 opposite each other, one water, and the other fuel Poly Diesel Tank 42 Lt - Dolium Pty Ltd . . . fill water through LH window, and on RHS have fuel fill neck to outer canopy above regular tank fill point. (That would give me 42lt water and 168lt fuel.)
The Dolium tray ones are like 20 to 25mm or so too high, even with my tray liner removed.
230 deep is fine too . . . once that is worked out, I'll build some drawers and work out best fridge location etc.
80lover96gxl
Check out Boab, been making water / fuel storage solutins for yrs, fantastic quality and as far as im aware ozzie made
Sent from my GT-I9000 using Tapatalk 2
I just got a Abber tanks to make me a custom one.
http://www.abbertanks.com.au/
$260 for a 55L tank to go where my spare wheel use to go under the tray. Made to my measurements as I'm in WA and he's in QLD. It was an oblong shape that was narrower and deeper at the front to fit the space well. Came with baffles and BSP inlet, outlet and breather.
Highly recommended.
Jesse
ashley6
Hi extra joss
Check out my thread; undertray PVC water pipe tank
Hopefully you will find some useful info on there.
Good luck;)
mypizzaiscold
Cool idea for showers, not sure about drinking out of it.
I have done exactly that on the top of mine. It works well for showers and washing up. Don't know if I'd drink it though.
the pressure doesn't tend to be all that amazing, but it holds 18L, and gets warm throughout the day.
I black duct taped it all to help with anti-fungal as well.
Hayden
BTFIVO
I was going to say it's "solar heated" now. But what you can do is install a schrader valve so you can pressurise the cannister. As long as all the seals are really good, you would only need a few psi, or alot if you want heaps, but a few is enough.
mypizzaiscold
Good idea, that will work well
RoughNReady
Like the way VW Kombi washer tanks are. They had a Schraeder on top to pump them up with. Beetles used the same concept but connected to the spare tyre for pressure.
BTFIVO
I never knew that. Interesting. You have to admire the Germans for their ingenuity. I suppose there was no washer motors back then. What did othed vehicles have of that era?
RoughNReady
Sure there were! My '72 beetle and '75 camper had those pressurized air setups. Both had an electric pump retrofit job done but yes the Germans liked their pneumatic setups. Pulling back on the lever on the steering column opened a valve instead of closing a circuit, so to the driver it is the same as any car, until you run out of pressure, or get a flat and need to use the spare.
BTFIVO
Hahaha. That's pretty cool, but it's kinda ironic coming from the Germans, them being favourers of capability etc.
muc the truck
Hayden
I did the same for a friends jackaroo only I painted it black 2pk paint. Only I used plumbing stand off brakets and painted them too , little more reliable than zip ties. It gets so hot in the sun he cant put his hand under it . My IR Digital thermometer hits over 80degs . wil be doing the same again for myself once I finish building my new tray and canopy.
IIt gets so hot in the sun he cant put his hand under it . My IR Digital thermometer hits over 80degs . wil be doing the same again for myself once I finish building my new tray and canopy.
Hi mate
What would be the purpose of that then if it's too hot to shower, unless you put it in a bucket then cold water and throw in a shower pump. ?.
