Keep an eye on the tubing, it is supposed to be a fuel / oil resistant type of hose to resist the chemical breakdown.
Heat could be an issue with PVC under the bonnet too over time.
From memory, that was an expensive part of the install, Pirtek hose, heavy and $.
Great to have it clear for a while though, so you can see what it's doing !!
Where you mounted yours . . . does the outlet hose run to a tap ?
Good spot for easy access you chose, mine is under the can (front of air filter housing) but no probs accessing every 4k to 5k or so to drain.
