Problem wit the CV joints
Finder06
I have been looking around for a 1 or 2 inch lift kits for my 06 pathy. Only problem is that everywhere I've been too they say that the CV joints can't take the strain of a lift. Is this true, or is it just them not wanting to do the work? Anyone have any input on this?
Does a 1 or 2 inch lift kit put too much strain on the CV joints or any other components for that matter?
Happy Trails
bmurray2250
Have you talked to ARB, TJM and EFS? I know on the Prado that 50mm is the max lift you can go but that is dependant also on the length and angles between the CV's. Raising the vehicle can add additional stress on the CV's but I would expect a 40mm lift is possible
croozza
you should have no problems lifting the Pathfinder, the CV's will be fine as you are only getting 25-38mm lift in them, and the suspension is still working through the original travel tolerences.
Jarh73
I think the issue with the R51 Pathfinder is not so much CV angles but lack of adjustment in the suspension to get the camber correct after being lifted.
Due to variances in manufacturing tolerances some Pathfinders can be easily lifted and have the camber adjusted properly others cannot.
For this reason they limit the lift to ensure that the camber can be adjusted easily.
In other words the higher you lift it the more likely it is that you will either not be able to or find it very difficult/expensive to adjust the suspension geometry to where it should be.
Justin
croozza
Justin
Which is why you only get 38mm lift maximum, this goes for all IFS or IFS/IRS vehicles
croozza
I think we can both agree on that one!
Justin
One thing I think people forget when lifting an independantly sprung vehicle is that you are actually narrowing the track of the vehicle, live or solid axle vehicles are getting the wheelbase shortened when they get lifted, and IFS vehicles get a combination of both.
Finder06
I hadn't ever thought of it that way croozza. But it makes a lot of since, I will definitely take your input and try to add it where I can on my Pathy. Thanks once again
