Primus 12volt Portable Shower
Hi Guys
My last trip in late November had me carting my Coleman On Demand Shower around for nothing, first night I went to use it and nothing, first fault in over 8 years, so cannot complain. If I cannot swim in a river it's a shower most nights.Well I'm pretty sure it's the battery that died.I will replace later on.
So I thought to myself I need at least a basic backup shower .Anaconda had this shower on Special from $35 down to $20. So I decided to give it a try and to be honest I'm pretty impressed with it. It's the new red one not the older blue model, which actually states it pumps out 7 litres a minute, someone messed up big time there and I think cause for new packaging etc
.You need to power the unit through cigarette lighter it's not like the Ironman one where the battery is with the pump. The water pumps out about 3.5 litres a minute when stuck to the glass shower, the box states 4 litres but it's still fine for what it is, rinsed out shampoo in my hair fine and I even had a shave just to prove a point.You need to regulate the heat yourself in a bucket first..I reckon the power through the 12 volt batteries is a lot better than there small rechargeable battery,Aldi"s works off a rechargeable too..I went through about 50 litres plus just to test the pump out, also I've had about 8 showers with it so far and no problems..
The switch is fully sealed and a breeze to turn on and off. You can also reduce the water flow at the shower head, sliding the bolt type thingy left or right
T.B.C
Alien d2
We have/had one of these.
Don't let the pump run with no flow as they will burn out very quickly.
After 2 years ours stoped working, pulled the bottom off and spun the impeller and it works for 8 showers over 2 hours.
Last trip it had stoped again and couldn't be fixed, the hose had also been damaged as it does not roll up neatly.
I've used the power lead and head/rose to make a new shower with a Whale pump and longer braided hose(original is to short to stand under).
From what I read we had a good run with it as most folk only get 2 years from these(subject to use and storage).
Towie
I have been using one of these for a few years they do rust out but easy to fix & for the price you cant complain.
Storing them wet is the problem i found so do not keep it in a sealed plastic container etc as they cannot dry out & therefore rust of course.
richardlnsw
Have always used these type, as Towie says, make sure it dries before storage. I had this with my 2 room shower tent set up year before last at the Vic. meet and it was used by quite a few people without any problems. If travelling I just hang a fold up bucket off the tow hitch and plug it into a socket in the rear and shower at the back of the car. For $20 even if you carried a spare it's still good value.
hiluxdriver
I've got one of these also, not a Primus one though it's some other brand I can't think of. Heating the water before hand can be a pain in the arse but I can have a wash and dance around a bit under the water and still only use about 8 litres. Suction cup thing on mine was shit so I chucked it and just hang on to the handle. Good bit of gear that packs away small and is quite valuable after a few days without a tub.
billolga
I have used a few of this type - they ALL end up rusting in the motor.
Don't get me wrong, for the price I have had a good run out of ALL of them, but I now find the ones with the Battery included like the IronMan type are much more convenient with a better Shower head.
To be honest I've used both and much prefer this type of head :eek: and spray..
billolga
:rolleyes: I'm not saying anything Swaggie :oops:
Been there, done that.;)
Hey Swaggie, they have been great for me, just don't let Olga near one as she tried to turn the switch SIDEWAYS to turn it off & broke it! (Just between you & me with NO ONE else reading the Forum, I was in the Bolickers when it was my turn to shower & had to short the switch to get a shower):eek::D
BTW I use an old one with the motor ripped out & a cheap Urn type Tap on the end to drop into my 10 Ltr Water containers (The Blue ones) to gravity feed my water to the back of my Wagon - The Ex-Motor end fits perfectly in the Water container. I can simply move it from container to container without removing them from the Wagon.
tankbloke
Way too much information there Bill.:D
Anthony.Veronica
We brought ours from aldi the blue recharging one. I had 3 showers and hubby the same. We used a 20ltr boiler pot heated to a nice temp. The only thing I didnt realize was to wet down turn off soap up and then turn back on to rinse. Did my hair with shampoo & conditioner. Still had power when we left. We let ours dry the day before we pack.
