Pressure Guide
Chubs86
Hey all just a quickie .. tried a quick search but could only find advice for sand. Just after a rough guide for tyre pressures on like soft mud (same for soft sand i pressume?).. rocks and general bush kind of tracks!! Some starting points to experiment and learn. Thanks.
Towie
Sand 15PSI
Mud/Rock 18PSI
General faster stuff & easy stuff 22-24 PSI
Or there abouts it will vary somewhat with the different weights of 4wds & there is some personal preference involved that comes with experience and testing your own setup..
03hilux
On my Hilux,I run 14-16 psi on sand, 22-24 on rock, and 36 on the road. Its worth while playing with your tyre pressures to find out what suits you 4wd and tyres.
frosty
And sand is'nt "just" sand either. Eg. I can run 21 psi on Fraser easily. And thats fully loaded including a trailer. At Stockton Beach, I have to run 14 psi, empty. Or, it just boggs down. Every surface is different. You just have to adjust your own thinking.
Yep i agree,you have to adjust to the surface at hand..Through Butcher Country just recently and rain over night i usually run around 22 psi when totally dry in this Country...This time i ran 16psi and it was great for suspension,great grip on clay and rocky ledges,not much sliding etc etc...
Just be aware if you go to low you risk running the Tyre off the rim...
frosty
Fraser Is! 18 Psi??? Really. There ya go. It's different for everybody. I'd never run that low. To hard pumping the tyres back up. Plus, looooong beaches. Tyres can get very hot with the high speed beaches. (80 clicks) Most times, I run 25-28 from Inskip to Cathedral Beach. Then let em down for the inland tracks.
03hilux
Just wanted to add i run 14 -16psi at the southern end of stockton, and 18 -22psi at the northern end along the beach front. The sand at stockton is variable so increasing the pressures toward the north give me better fuel economy. If i ran lhigh pressures at the souther end around near the Sygna wreck, i dont think i would make it from the beach entrance to the wreck.
leensw1965
just did Anna bay run in my Prado, ran on 20psi, as a newbie I only did about 30kmh max, parts of Anna bay -Stockton can be dicey , up near tin city it gets real soft, mate bogged in briefly before going low-low to get out.
markfarrell1980
I recently got back from Fraser 2 weeks ago and 20psi everywhere inland and at the limit of the high tide mark.
Just try a few different PSI and see how you and your 4WD handle
Outrage
Experience with the patrol.
Rutted tracks where there is going to be sliding around hitting sidewalls, anything below 20psi seems to greatly increase the chance of popping beads. Ran 18 with the new tyres in similar situations with no ill effects so far.
Otherwise I aim around 16-18 for most low speed high country, like a smooth ride, find anything over 20 just rattles things around too much and any shale surfaces tear into the tyres.
Real balance problem for low speed4bying - rock/mud is the lower the pressure the more traction, but less clearance and higher chance of popping beads.
If I'm just travelling to camp along basic dirt tracks, run about 25.
