Reddave
This is ripped from another forum which isn't as active as I like these days so a bit of a backstory:
November 2014 I traded my GU for this 120 Prado, I'm still adding to it but is a ripper car
As good as the GU was, it was time for a change and something with "on road manners"
The GU had been out 3 times this year due to other commitments and was going to waste in my driveway dropping kids off at school, so it was time for it to go.
I ummed and ahhed about this decision for months before finally pulling the pin last year and trading the GU on a Prado
It's a good base as an in between car for us that will actually drive like a car on road, yet will handle touring duties with ease off road.
The specs:
05 V6 Auto GXL with leather
2" Ironman lift
Cooper All Terrains
GME UHF
Alloy bullbar
Driving lights
Rear power
First things that need to be done:
Underbody bash plates
ARB Deluxe bar
Dual batteries
Anderson plug
Snorkel
BFG All Terrains
On the wish list:
Front and rear E-lockers
Steel rear bar
Roof top tent
With 180lt of fuel capacity should be good on fuel, the average fuel consumption should be better than my ZD30 even with the petrol engine.
Don't have any long distance trips with planned in the immediate future, but should still be able to conquer the Simpson and the Cape. Without the reliability issues in the back of my head about the GU going bang!!!
Not too mention being able to actually tow my camper well.
Big day in the workshop, the transformation began
Trailer brakes:
Safari Snorkel:
Very well made, but the template leaves a lot to be desired, I'm not 100% happy with the way that it follows the guard, Even though all the edges lined up I feel that it was up to 5mm too low.
Redarc Solenoid and Anderson plug to the rear:
I had the Ducks nuts Piranha system on my GU, but found out the hard way when I got a flat main battery that I couldn't jump start it using my auxillary battery unless I had jumper leads, so went with something alot simpler this time.
ARB Under vehicle protection:
Very well made, instructions were very vague, but in ARB's defence these particular plates suit 3-4 different Toyota types.
I like that there is access holes that make it easy to service the vehicle without removing them. Also the Transfer case skid is around twice the weight of the factory one and picks up through the Transfer instead of just over the top.
Once I got home I started to remove alot of excess wiring that second hand cars seem to accumulate when accessories are fitted and then removed. The accessories get removed but the associated wiring never does in my case
The specs:
2" Ironman lift
Cooper All Terrains
GME UHF
Alloy bullbar
Driving lights
Rear power
ARB Deluxe bar
Dual batteries
Anderson plug
Snorkel
BFG All Terrains
On the wish list:
Steel rear bar
Roof top tent
Trailer brakes:
Safari Snorkel:
