Power Steering Conversion 1984 Hilux
Shep
I have a 1984 Hilux that I would like to fit with power steering.
These set ups seem hard to find and I was wondering what my options are in terms of fitting something from a later model Hilux, are Surf boxes the same? 90 models seem very similar are they suitable? Any help appreciated.
Shep
croozza
they are hard to find because not many hilux's had power steer back then, however, the 4runner did, so if you changed your search from hilux to 4runner you might get a better responce. The surf might fit, but just remember that 80% of the gear on the surf is different to hilux/4runner.
dudelux
You can convert your non-power steering lux to power steering. Its not that big a deal, but youll have to change your steering to either cross-over or histeer. Which means no more stoopid j-arm style steering.
You buy yourself the steering box from any IFS 4runner/Lux, and buy yourself the cross-over or histeer kit, from someone like Locktup4x4, or Superior, Snake racing, etc.
Fit the IFS steering boxm, along with the histeer or crossover kit, and your done.
The new steering will allow the front suspension to work alot more, gaining more flex, and more control on and offroad.
Basically, the old j-arm style steering works via the steering box, which has a pitman arm(which moves forwards and backwards), which joins the draglink, which joins the j-arm, which turns the drivers side wheel, which is connected to the passenger side wheel via the tie-rod.
And then crossover or histeer both work the same way, steering box, which has a pitman arm(which moves left and right), which joins the draglink, that goes down to the passenger side wheel, which is connected via the tie rod to the drivers side wheel.
The only difference between crossover and histeer is that the tie-rod is above the leaf springs with histeer, as opposed to in front of the axle with crossover. So everything is safely tucked up out of harms way.
I hope this helps and makes sense mate.
Im about to fit power steer and histeer to my 86 Lux.
I bought my IFS steering box from a wrecked 91 4runner, and got all the hoses, resovoirs and lines with it.
Good luck.
dudelux
It depends on how much you want to modify it, and how much you can do yourself.
I am going to be fitting all my parts, I own a decent welder, which will come in handy.
Its not cheap though, I bought a whole heap of suspension and steering parts from Locktup4x4 all at once, so I got a discount off the advertised prices, Tash and Chris from Locktup4x4 are great like that.
Look at the Locktup4x4 website, click on the bits you need and go from there.
Also check out the Superior Engineering site.
Theres a few sites that you could buy from, BudsCustoms, Snake Racing, Low Range Offroad.
Goz 759
i was wondering dude lux did you just bolt the IFS steering box in or did u have to put a power steering pump and everything else that goes with it?
dudelux
The whole power steering setup needs to be fitted, steering box, pumps, hoses, pulleys, etc.
Check out ebay seller Phats4runners, hes at West Gosford, his name is Matt, nice guy, and he wrecks/parts out gen 1 4runners. You might get lucky and find he has the power steering setup you need.
